Thread: L67 3.4" Pulley vs L32 3.6" Pulley
Results 1 to 18 of 18
  1. #1 L67 3.4" Pulley vs L32 3.6" Pulley
    Feb 2019
    ON
    Hey guys,
    I apologize if this has been talked about before, I just can't seem to find the definitive answer I'm looking for.
    I'm aware that the Gen V blower is a more efficient design and am aware that the L32 is more prone to KR. I was originally going to do the work to drop to a 3.4" pulley in my '06 GT...but after doing some reading, I've seen a few places that say that dropping to a 3.6" in an L32 yields the same results as dropping to the 3.4" on an L67. Can anyone chime in on this.
    Secondly, I have a FWI, 180* thermostat, Autolite 104's and a front PLOG...I was considering bypassing the 3.6" and dropping to 3.5" pulley...obviously I would need a good tune but do you guys think I would be safe going this root without doing rockers or an IC? Would probably need at least headers no?
    I'm not looking to spend a ton of money on this car...just wake it up a bit. Any info would be a huge help
    Cheers,
    Matt
  2. #2 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Kemmerer, Wyoming
    you'll make more power on a bigger pulley with no kr than a smaller pulley with kr. headers are cheap, like 300 bucks. if you have an mps, why not drop to a 3.6" pulley then scan for kr and if you don't have any, then drop to the 3.5" pulley.
  3. Thanks BadDecisions thanked for this post
    Likes BadDecisions liked this post
  4. #3 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    3.6 is about it.
    meth is doable but it needs custom tuning. aka you need your own tuner, or have a local tune it. with just meth and add a 3 inch down pipe i bet you can run a 3.2 pulley.
  5. Thanks BadDecisions thanked for this post
  6. #4 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Jul 2017
    macomb mi
    I put a 3.5 on a car 2004 gtp (gen 5) with sd headers, and a huge fenderwell intake, and the other small things you metioned I where I live it never gets real hot but when it got above 95 degrees it would have like .5 knock
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  7. Thanks BadDecisions thanked for this post
  8. #5 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Jul 2017
    macomb mi
    I have a 3.5 or 3.6 lying around im willing to sell
  9. #6 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Feb 2019
    ON
    Thanks for the info guys. I've got a line on some SLP headers on the cheap so I might just go ahead and pick those up to be on the safe side.
  10. #7 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Feb 2019
    ON
    Quote Originally Posted by tzerilli View Post
    Would is be a press on or MPS? I'm looking to go MPS but its not mandatory that I do. I would need a puller though
  11. #8 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Jul 2017
    macomb mi
    they are both MPS only looking to sell one though since I need one for fuel savings haha I do lots of driving certain parts of the year but yeah get some headers they are worth it my speed daddys were a pain to install but I heard SLPs aren't as bad. good luck
  12. #9 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Dec 2018
    Lehigh Valley, PA
    As soon as it warms up around here, I'm putting headers, Autolite 104's, water/meth injection and a 3.4" pulley on the '04 GTP. I'm looking into Intense Performance for the tune.
  13. #10 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Kemmerer, Wyoming
    Quote Originally Posted by CopperGTP View Post
    you might have better luck if you buy a tuner from intense and his tune, then make custom adjustments to the fuel yourself. you will need to cut fuel because that's how water/methanol works.
  14. #11 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    you "NEED" a wideband afr gauge before the meth, and you need a in car tune for the meth. its just maf adjustments, but you still need a tuner in hand to even do remote tuning.
  15. #12 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Dec 2018
    Lehigh Valley, PA
    I'm not doing straight meth, gonna do 30 percent meth, so it won't really affect AFR's too much. I've got a couple buddies with supercharged Cobalts that have run this setup with no problem and it does really help cool down the charge. You can touch the supercharger after a dyno run and it's barely warm.
  16. #13 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Feb 2019
    ON
    Forgive me for my lack of knowledge here but when getting the car tuned with meth, would the tuner not just read AFR from the program (HP tuners or whatever) and adjust accordingly to that? I'm assuming that most people are just running an AFR gauge for piece of mind?
  17. #14 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Kemmerer, Wyoming
    the tuner will read the commanded afr and the narrowband gauge, which isn't always accurate. you have to make the adjustment yourself. there isn't anything automatic about tuning.
  18. #15 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Feb 2019
    ON
    Quote Originally Posted by SgtMarshal View Post
    Ahhhh gotcha . Thanks for the enlightening
  19. #16 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    meth adds to the afr, the tuner cant see actual afr with out a wide band plugged into it. 30/70% meth with add a lot to the afr.
    you need to remove fuel from the maf till your afr is in the 12's, then turn the meth on, it will lower the afr to 11's where it needs to be. from there you need to fine tune the maf some.
    this is from one of my last scans from retuning meth and a N* tb with a gen5. see the bottom row, commanded afr is set to 11.4 in the tune, then you got wb error, then in red the actual wide band reading from my wide band. the wide band didnt get to 11.4 on its own. i had to make that happen.
    L67 3.4" Pulley vs L32 3.6" Pulley-237-jpg
    if you just spray meth you'll be super rich on the afr and the car wont be fast at all. its rather slow when its flooding out.
    L67 3.4" Pulley vs L32 3.6" Pulley Attached Images
  20. #17 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    Kemmerer, Wyoming
    i'm curious how you are going to mix the water/methanol 70/30.
  21. #18 Re: L67 3.4" Pulley vs L32 3.6" Pulley
    30% meth is 70% water per gallon. where 50/50 is just that 1/2 gallon to a 1/2 gallon.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
  2. WTB: 3.6" or 3.8" press-on pulley, 3-Guage pillar pod
    By a97GTP in forum Wanted To Buy - Parts
    Last Post: 02-11-2014, 08:03 PM
