Thread: Where does this bolt go
Results 21 to 40 of 62
  1. #21 Re: Where does this bolt go
    Chats
    243824
  2. #22 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Oh okay, which one gets left open? All the vacuum lines are hooked up
  3. #23 Re: Where does this bolt go
    Chats
    243824
    the you never touched, stays open, theres two on the right side, leave that one open. its got a funky clip on it too, there used to be a foam cap over it, its long gone and not a issue.
  4. #24 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Okay awesome, thank you so much for your help on this, I'll go back up there and hope for no codes
  5. #25 Re: Where does this bolt go
    Chats
    243824
    its a small plug that goes to the little box there with the two vac lines, make sure its plugged in.
  6. #26 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    I made sure it was plugged in, hopefully it passes inspection
  7. #27 Re: Where does this bolt go
    Chats
    243824
    your gonna need to put some mile son it so all systems show ready. you can see this in the t app or a hand held scanner, looking for "im readyness" once all them show ready, your clear to go to inspection.
  8. #28 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Okay awesome, well I went and noticed my check engine light doesn't come on at all. Could that be the 1671 code?
  9. #29 Re: Where does this bolt go
    Chats
    243824
    P1671 - GM Forum - Buick, Cadillac, Olds, GMC & Pontiac chat yeah that means the cel light is not working you fill fail inspection for that one.
  10. #30 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Dangit, lol looks like I got another job today
  11. #31 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Well I just took it off and I have no security or check engine light even installed
  12. #32 Re: Where does this bolt go
    Chats
    243824
    when you turn the key to run all the dummy lights should come on. some times its the bulb went dead, a cluster swap would be easy enough if your not a soldering guy.
  13. #33 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    So their was no bulbs at all, to install a new bulb would I need a new cluster?
  14. #34 Re: Where does this bolt go
    Chats
    243824
    theres a bulb, its a little led thats soldered in the board. i dont know much more then that on the topic.
    jy cluster should fix it tho.
  15. #35 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    Alright I'll go check out the junkyard in a little bit and get one. Thank you for your help on this journey lol
  16. #36 Re: Where does this bolt go
    Chats
    243824
    with any luck its the last thing you need done for a while.
  17. #37 Re: Where does this bolt go
    Sep 2017
    Texas
    Chats
    I hope so also, I'll be going to tomorrow so looks like I'll be doing the water deflector now instead
  18. #38 Re: Where does this bolt go
    St. Louis
    Chats
    The CEL on a 98 is an LED? I know the one on my 00 GT died and it was just a regular replaceable bulb.
  19. #39 Re: Where does this bolt go
    Chats
    243824
    it maybe a very small bulb, but its still soldered in the board is is not? back lighting bulbs are the easy ones to change.
  20. #40 Re: Where does this bolt go
    St. Louis
    Chats
    Probably. I don't remember for sure and it's far too cold to go pull it again. I want to say it was smaller than the normal 194's though.
    Edit- here's a post that may help--> My service engine soon bulb is burned out?
  1. What is this bolt?
    By mhunt in forum Introductions/Noob Questions
    Last Post: 12-19-2016, 12:18 PM
  2. Grand Prix vs Subaru WRX [Bolt ons] and Mitsubishi EVO [Bolt ons] [Videos]
    By ADrugDealer in forum Track Sessions and Kills
    Last Post: 05-06-2014, 12:02 PM
  3. Bolt ons!?!?!?!?!?!
    By clodracer2000 in forum Engine
    Last Post: 12-05-2012, 02:04 AM
  4. WTB: Bolt in TOG dp.
    By glanzergtx in forum Wanted To Buy - Parts
    Last Post: 02-28-2012, 09:55 PM
  5. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
