Thread: Gen V M90 rear needle bearings
Results 1 to 2 of 2
  1. #1 Gen V M90 rear needle bearings
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I am getting ready to rebuild my Gen V and was reading that the procedure is different than the IV. I can’t find the Gen V procedure in any of my searches. Do any of you know where I could find that info as well as the rotor pack????
    I bought a complete rebuild kit from ED.
    Thanks all
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Gen V M90 rear needle bearings
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I needed to buy a blind bearing kit from amazon in order to get the needle bearings out. You need to break the plastic bearing case and remove all the loose bearings. Then use the blind hole puller with the press option instead of slide hammer. Heat lightly while pressing/pulling out.
  1. Symptoms of bad needle bearings?
    By suitercrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2016, 12:08 PM
  2. Gen 5 Needle Bearings
    By buford1972 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2015, 10:57 PM
  3. Needle bearings
    By BLUESMOKEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2014, 09:56 AM
  4. M90 supercharger needle bearings
    By 88formula in forum General Tech Discussion
    Last Post: 11-04-2012, 07:05 PM
