Thread: LS7 lifters - rocker torque?
Results 1 to 7 of 7
  1. #1 LS7 lifters - rocker torque?
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    Chats
    Do the rocker bolts still get torqued to 11 ft/lbs + 90° when using LS7 lifters? (TTY bolts)
    Pre-Production 2004 GP GTP Comp G / 91,000mi / TransGo Shift Kit, Spectre Open Cone, 180 Tstat, AL605's, ZZP 3" catted DP, ZZP front PLog, Intense PCM, GMPP Sway Bar
    Access Old "How-To" Links
  2. #2 Re: LS7 lifters - rocker torque?
    May 2008
    Schuyler, NE
    Chats
    265
    Yes. That will never change unless you switch rockers or bolts to non oem.
  3. #3 Re: LS7 lifters - rocker torque?
    SE Level Member SlowGTP2004's Avatar
    Jul 2019
    Minneapolis Minnesota
    Chats
    What would be the torque spec for yt 1.9 rockers and 90# springs?
  4. #4 Re: LS7 lifters - rocker torque?
    May 2008
    Schuyler, NE
    Chats
    265
    What bolts?
  5. #5 Re: LS7 lifters - rocker torque?
    Jul 2019
    Chats
    Im not sure...im pretty sure they are the zzp reusable bolts or they are the bolts that intense supply'swith there 1.9 rocker set up. They have a allen head so i know they are not factory.
  6. #6 Re: LS7 lifters - rocker torque?
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Chats
    1591
    ZZP is now stating red Loctite and 23ftlbs for the re-usable Allen head bolts (no extra degrees).
  7. #7 Re: LS7 lifters - rocker torque?
    May 2008
    Schuyler, NE
    Chats
    265
    Yeah that's what I would go with. Be careful. Those bolts suck and can break.
  1. ZZP ER rocker kit, valve springs, and rocker bolts
    By bachert24 in forum For Sale - Parts
    Last Post: 03-18-2016, 12:00 AM
  2. Appropiate Torque specs for Rocker Arm Bolts
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2015, 01:08 PM
  3. Comp Cams Re-useable rocker bolts - torque spec?
    By Elite6 in forum General Tech Discussion
    Last Post: 07-14-2012, 02:51 PM
