Thread: P1260, fuel pump wiring or something
Results 1 to 20 of 21
  1. #1 P1260, fuel pump wiring or something
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Chats
    Was out on a drive tonight and did a wot pull up to about 90 and this code popped up as pending. Fuel pump is about a year old. The only thing I have changed recently is I upgraded to 60# injectors and am still dialing in the tune. Currently my fuel trims are still pretty off -10 to 0 ltft. I've been worried I'm maxing out my current pump as I'm on a 3.4 e85 setup and the pump I have is a Delphi that is for a gt which when researched seems to flow less then the supercharged models.
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: P1260, fuel pump wiring or something
    May 2008
    Schuyler, NE
    Chats
    265
    Do you have a rewire?
  3. #3 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    I have a caspers one sitting in my room waiting to be installed im just planning on getting a better pump, switching the connector to the 4 flat style and doing the install together. Currently it's all stock wiring. No alt booster, or alt rewire or anything like that either.
  4. #4 Re: P1260, fuel pump wiring or something
    May 2008
    Schuyler, NE
    Chats
    265
    Hmmmm, ok. For that code to trip, it needs to meet the improper voltage specs for 30 seconds...which leads me to believe there is something else going on.
  5. #5 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Well it's nice you know why it actually sets. Online it pretty much just says your pcm, fuel pump, or wiring is messed up. What I wasn't sure off is if this code would set if maybe i was maxing out the pump. I've had a kr problem but it's only ever happened in the very top of 2nd or 3rd making me think maybe it's a fueling thing. I should probably be watching my wideband when this happens but I'm always to busy watching the road during wot pulls.
  6. #6 Re: P1260, fuel pump wiring or something
    Chats
    243824
    you got that fat plug on the front of the engine from the coil harness/ cam harness. mine got dirty i guess and was causing the fuel pump to quit. i would get up to 3 codes, 3x signal, crank and something else from it.
    cleaned that plug added some grease and aint had a issue since. its a free repair at least if thats not it.
  7. #7 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Are you talking about the icm plug? Unrelated I've been getting a p0300 code on long highway trips. Only highway though, I don't notice these supposed misfires either. Might try changing out the icm since I have a spare.
  8. #8 Re: P1260, fuel pump wiring or something
    Chats
    243824
    no the fat plug that lays on the lim just past the dog bone on the pass side.
  9. #9 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Ok I think I know what your talking about. From memory I think there's two rows of four wires to it?
  10. #10 Re: P1260, fuel pump wiring or something
    Chats
    243824
    the fat one just past the dog bone mount. its touching the fpr.
  11. #11 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Ok that's the one I was thinking of. I'll try to clean it out. I know it's really dirty. Everything in the stupid injector valley is dirty
  12. #12 Re: P1260, fuel pump wiring or something
    Chats
    243824
    its a weather tight plug, but that dont mean the pins cant get tarnished over time, if you got electrical parts cleaner, spray it down on both sides, then work the plug off and on a bunch of times, then di-electrical grease and work the plug off and on a few more times.
  13. #13 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Checked that plug and it was spotless. 😯
  14. #14 Re: P1260, fuel pump wiring or something
    May 2008
    Schuyler, NE
    Chats
    265
    I would install your rewire and see if that makes a differemce.
  15. #15 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    Ya I'll be installing the rewire probably next week. So far the code is still pending and I've gone on about 3 "trips" so it'll either set the light or go away pretty soon here. My car has a habit of popping codes one time and then they disapear never to be seen again.
  16. #16 Re: P1260, fuel pump wiring or something
    Oct 2015
    Chats
    I installed the rewire last Thursday and erased the code. So far it hasn't come back up
  17. #17 Re: P1260, fuel pump wiring or something
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Chats
    I bought a fuel pump for a 99gt and never installed did l67 engine swap and tuned pcm from zzp installed got car running but doesn't start unless with starter fluid but I got the p1260 one site said it's a fuel pump wiring or speed control but I installed the new pump and I got the 1260 code is it cuz it's a gt fuel pump and the pcm is a l67 tune
  18. #18 Re: P1260, fuel pump wiring or something
    Sep 2018
    Saint Louis
    Chats
    Could I have messed up the wiring it wasn't color coded with the same colors just the black n grey wire matched and the other 2 were blue and black with white line thru black and orange with white stripe and solid black
  19. #19 Re: P1260, fuel pump wiring or something
    Apr 2015
    Columbus, OH
    Chats
    246
    The thicker two wires are for pump power. The other wires are for fuel level sender. Do you hear the pump prime when you turn the key on/engine off?
    Top Swapped 01 Imp
  20. #20 Re: P1260, fuel pump wiring or something
    Sep 2018
    Saint Louis
    Chats
    Yes I do hear the engine prime it send the fuel to the rail the rail is leaking from the valve
  1. Wiring caspers fuel pump hotwire into a gt without speed relay.
    By suitercrew in forum General Tech Discussion
    Last Post: 04-03-2017, 11:46 AM
  2. Fuel pump canister wiring question
    By buford1972 in forum General Grand Prix Discussion
    Last Post: 03-07-2016, 11:17 PM
  3. How to install a racetronix fuel pump wiring kit on a 04+
    By gambler87 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2015, 08:52 PM
  4. Fuel Pump wiring diagram for 1996 3.4L
    By 96LimitedEdition in forum General Tech Discussion
    Last Post: 04-14-2010, 08:39 AM
  5. Fuel pump wiring diagram for 1996 Grand Prix LE with a 3.4L
    Last Post: 07-23-2009, 01:03 PM
