Looking to see if parts from a newer say 05 or 06 will fit on my 97? Interior wise. I know engine and trans will. Thanks
Sent from my SM-G920R4 using Tapatalk
Transmission isn't a direct swap. The internal wiring harness is different. The pin assignments are different.
That's the GM recommend method of removing and replacing the engine and transmission assembly. Again, you can't just plug the 03 and newer transmission into your 97 to 02 engine harness. The electrical connector pin assignment on the 03 and new transmission is different.
ExLimey can I message you with some questions I have about differ cars
Sent from my SM-N900T using Tapatalk
