Thread: droped torx screw down steering shaft housing.
Results 1 to 5 of 5
  1. #1 droped torx screw down steering shaft housing.
    Dec 2013
    Niagara Falls Ontario
    I just dropped the torx screw from the multifunction switch down the steel housing that surrounds the steering shaft. Is there any way to get something that fell down the steering shaft housing?
  2. #2 Re: droped torx screw down steering shaft housing.
    You could pull the column and tip it upside down.
  3. #3 Re: droped torx screw down steering shaft housing.
    Dec 2013
    Actually i was hoping for a fix that wasn't going to that big of pain. Also in my opinion I would think that a bolt that fell down the steering column may be serious as it could jam the steering wheel when driving. is that true, or could i just leave the bolt down there? Thanks
  4. #4 Re: droped torx screw down steering shaft housing.
    My suggestion was a little vague because we have no idea what you are working on.
    Year would go a long way to potentially helping.
  5. #5 Re: droped torx screw down steering shaft housing.
    pull the plastic off, its clipped on. then unbolt the metal knee boltster. you screw could be on the metal lip at the bottom, ot on the card board foot cover.
  1. Loose steering after replacing intermediate steering shaft on 06 GP GT
    By Tross901 in forum Other 3800 Powered Cars
    Last Post: 06-03-2015, 10:56 AM
  2. lost a screw below the balancer shaft... like a boss
    By The Gut in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2015, 06:37 AM
  3. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  4. Steering Intermediate Shaft
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2009, 12:22 AM
  5. What size torx for lower control arm screw
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2009, 08:38 PM
