Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 401 to 420 of 437
  1. #401 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Chats
    K thanks man
  2. #402 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Kemmerer, Wyoming
    Chats
    60223
    will a top swapped L36 block hold up to an aggressive XPZ intercooled build?
  3. #403 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Florida
    Chats
    292
    Most prefer the lower compression l67 block so they can run more boost. . Also the higher compression is less forgiving when it comes to tuning. . What goals are you trying to reach? . Most combinations have been done before...
  4. #404 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Chats
    40479
    and intercooled XPZ build will easily run on an L36 block. on an L67 block you might run out of pulley and timing to be had if you push it hard whereas the L36 might have slightly more headroom to grow.
  5. #405 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2012
    Valencia
    Chats
    Quote Originally Posted by redlinepontiac View Post
    zzp sells a lower intake to mate m90 with NA heads, its a meh set up at best. grabbing a L67 balencer, idlers heads and lower intake would be a better route.
    Is there any more info on this? I cant seem to find anything around. Is this a part they no longer sell? I realize this thread is aged.
    Daniel - Code name ILMODC (il-maude)
    Current ride: 2000 GT, 1998 GTP (wifes) -
    Work in Progress: 1987 Trans Am – KnightHawk Edition (5.3 LSSwap)
  6. #406 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Chats
    243824
    hardly seems worth it when you could do a turbo for the same price. http://zzperformance.com/3800/l36-supercharger-kit.html they might just sel th elim still, iirc it was 300 bucks alone. someone had one for sale not to long ago, no idea if it sold or not.
  7. #407 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Chats
    Seriously theres so many people selling complete top swap kits for the same price as just that manifold. Just saying.
    Sent from my LG-H901 using Tapatalk
  8. #408 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2017
    Florida`
    Chats
    Do the fuel lines from the l36 set up clip into the fuel rail for the l67 just fine? Or do I need some kind of adapter?
  9. #409 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Chats
    243824
    they fit right on, but not in the same location, so the bends are off a bit. a little finagling and you should be ok.
  10. #410 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Oct 2015
    Chats
    I have a 99 with the quick release style fittings. They swapped out perfect. Like Scotty said the bends will be off a little but that's not a big deal, just be fragile with them.
  11. #411 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Oct 2015
    Chats
    Quote Originally Posted by SgtMarshal View Post
    I'm not talking about the quick release fittings, I'm talking about the spots where the fuel rail bolts to the lower intake manifold.
    Thats weird my l67 fuel rail bolted right up. It doesnt even make sense that it wouldnt bolt right up. L67 lim should work with l67 fuel rail.
  12. #412 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Oct 2015
    Chats
    I was using L67 fuel rails with an L36 lower intake manifold. Of course your L67 rails will bolt to your L67 lim.
    Well either way, yes the lines will fit and since your doing a top swap your obviously going to use the correct lim so the fuel rails will also fit no problem.
  13. #413 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Chats
    Step 28 what all is need for the fuel rail looking to install a l67 into a 99 gt
  14. #414 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2015
    Columbus, OH
    Chats
    246
    Nothing needed, your stock lines will hook-up. The fitting feels kinda janky, loose, but I ran it that way for 4 years. I have -an line now, but still using the quick connect fittings. I'll eventually get rid of the quick connect fittings because when you have them on and off a lot like me, they will leak and need new o-rings.
    Top Swapped 01 Imp
  15. #415 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Chats
    Ok got the motor and transmission in swap out my 99 gt motor and transmission from a Bonneville l67 00-05 01 gtp transmission car runs but it feels like supercharger is not working didn't but the zzp l67 swap kit remapped the map sensor to the front and the evap sensor just the boost bypass valve isn't connected snipped the connector from the junkyard wanted to know if I gave it a ground and power would it work wasn't trying to order zzp kit but I see there's plugs into the pcm pin 77
  16. #416 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2015
    Columbus, OH
    Chats
    246
    What pcm or tuner are you running?
    Top Swapped 01 Imp
  17. #417 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Chats
    No tuner stock pcm
  18. #418 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Chats
    Looking for someone who tunes or I zzp pcm 1 gud enough
  19. #419 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Chats
    243824
    you cant drive that on your old stock na pcm and na tranny gears. you need a tune for this swap or you'll blow it all up. tranny and the engine. way to much timing. kr city, injector data wrong, trans gears are wrong with a host of other settings.......park it asap. get a tune.
  20. #420 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Sep 2018
    Saint Louis
    Chats
    Glad I checked this will keep it parked for now so will zzp pcm b enough
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
