Thread: Close to having everything for my top swap, can someone verify all this for me?
Results 1 to 20 of 20
  1. #1 Close to having everything for my top swap, can someone verify all this for me?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Chats
    96
    Alright so I am getting close to having everything I need for my top swap, just wanted to take a few pics of everything I have and say what I think it is and what I think I still need and have you guys verify it for me so I can finally get this all installed.
    Supercharger
    MPS hub
    Fuel rail
    Supercharger gasket
    LIM gaskets
    Valve cover gaskets
    Left? Head gasket
    Harmonic balancer
    Heads
    Coil pack bracket?
    Now if all of that is correct and you guys don't see anything that I have but missed then I believe all I need is:
    Right? head gasket
    Supercharger oil
    MPS pulley
    Pulley belt
    Head bolts
    Thread sealer
    Rocker bolts
    Tensioner
    Idlers
    Colder t-stat
    Spark plugs
    Lim
    Does this all seem right or am I missing something? Thanks for all the help!!
  2. #2 Re: Close to having everything for my top swap, can someone verify all this for me?
    GTP Level Member
    Sep 2011
    Motown
    Chats
    921
    you already have a lim...its on the supercharger already.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  3. #3 Re: Close to having everything for my top swap, can someone verify all this for me?
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    Chats
    1415
    wheres your sc idler pulleys and tuned pcm
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  4. #4 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    Quote Originally Posted by Classy Pontiac View Post
    See that is what I thought to but the guy I bought it all from said it didn't come with the lim... Thanks for clearing that one up for me! And as for the idlers I have that on my list of parts I need and the tuned pcm is happening after I put it all in. I am getting it tuned at a local shop
  5. #5 Re: Close to having everything for my top swap, can someone verify all this for me?
    Sep 2012
    bridgeport,NY
    Chats
    1415
    while the blower is off you should block off those coolant holes
    Chats
    64942
    Well that bracket is not the coil bracket. Its the drivers side dogbone bracket.
    Those valve cover gaskets are crap.
    Do you have the sc to lim bolts? Stand off for the lower sc belt idler w/bolts?
    Injectors w/connectors?
    Is your car an 04+? If not, you need an l67 fuel rail, not l32.
    If newer than 05? Youre going to need another pcm to flash.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Chats
    37
    That's red painted brace isn't for your coil packs . That's the dog bone mount that mounts to the drivers side head
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  8. #8 Re: Close to having everything for my top swap, can someone verify all this for me?
    Sep 2012
    bridgeport,NY
    Chats
    1415
    i have the injector connectors you will need if you are running gtp injectors they in my for sale thread
  9. #9 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    So am I missing one dogbone bracket or do I not even need that one?
    I have the bolts from the sc to lim. I don't have the standoff, can you show me what that looks like?
    I thought you didn't NEED the injectors but it was recommended?
    I have a 04 so I am good on my fuel rail and pcm
  10. #10 Re: Close to having everything for my top swap, can someone verify all this for me?
    Chats
    64942
    you need the coil pack bracket because thats where one of the idlers and the tensioner mount.
    No idea where to find pictures of the standoff, hopefully someone else will post some up.
    Stockers might be good for 220 CHP or something in that region.
    L32's will support a bunch more. Which you will probably flow enough air to make granted you're installing headers as well.
    If not, I'd look into a 4.0/4.2 MPS.
  11. #11 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    Alright so I will also grab the connectors and injectors. Is the coil bracket the other dogbone mount I am missing? I am a little confused on that
    Warsaw indiana
    Chats
    37
    Yea it's the mount on the passenger side of the engine it's the whole dealio . It's the dog bone mount / coil pack mount . It bolts on the passenger side front head then from there the supercharger tensioner bolts onto that and I believe an idler pulley as well
    I don't have the best picture of it but ill try to search through my pictures and find one
  13. #13 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    Oh ok I see it now, thank you for the picture. I also looked at it on google to get another look at it. I appreciate all the help I am getting. Is there any way anyone can confirm that I have the left head gasket and not the right one?
  14. #14 Re: Close to having everything for my top swap, can someone verify all this for me?
    Sep 2012
    bridgeport,NY
    Chats
    1415
    you research that harness yet
    I live here. DirtDog's Avatar
    Jun 2012
    Chats
    1266
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Impatient are we young skywalker
    Sent from my DROID RAZR using Tapatalk 2
  16. #16 Re: Close to having everything for my top swap, can someone verify all this for me?
    Sep 2012
    bridgeport,NY
    Chats
    1415
    very sorry its late and cod aint much fun anymore
  17. #17 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    Nope not yet, I am a little busy at the moment so I probably won't be able to do some good research till tomorrow
    Jun 2012
    Chats
    1266
    Cod got old after world at war
  19. #19 Re: Close to having everything for my top swap, can someone verify all this for me?
    Sep 2012
    bridgeport,NY
    Chats
    1415
    i did a little for ya you can use the l67 swap kit and wire the bbv solenoid connector into your harness as for the map sensor im stumped
  20. #20 Re: Close to having everything for my top swap, can someone verify all this for me?
    Oct 2011
    huntley
    Chats
    96
    I will figure it all out tomorrow when I get some free time. If anyone would like to help out and shed some light on whatever it is that he is talking about would be great!
  1. close please
    By 00grandprixgtp in forum Wanted To Trade
    Last Post: 09-20-2012, 05:33 PM
  2. is anybody close to this?
    By Below Average Joe in forum Midwest
    Last Post: 10-28-2011, 02:50 PM
  3. how to verify mileage
    By SPONTSZ in forum General Tech Discussion
    Last Post: 10-12-2010, 10:31 PM
  4. Am I getting Close
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 10-26-2009, 06:09 PM
  5. Ugh!! I'm SO CLOSE!!!
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-24-2009, 11:59 AM
