Thread: Multiple misfire?
Results 1 to 12 of 12
  1. #1 Multiple misfire?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Ok so since I changed my LIM gasket and replaced the spark plugs a misfire occurred on the first start up. Then it stopped and went away until i drove it 900 miles to Montana. Then it misfired and had a code PO300, which is multiple misfire. Once I got to where I was going I was driving around town and on my way to the part store to clear the code it went away. And only when I drive at a constant 80MPH for atleast 50 miles the code comes back. But then after driving in the city for a while it goes out again. They are new spark plugs and wires. Anyone know what is wrong? Thanks
  2. #2 Re: Multiple misfire?
    It's most likely either a plug or wire. Drive/scan and determine which cylinder is misfiring.
    Quadruple check your wiring to the plugs. Make sure you didn't cross them.
  3. #3 Re: Multiple misfire?
    As it goes like so...
    From the top down on the coils...
    6
    and the engine if your standing in front of it looks like this...
    2 4 6
    UIM/TB
    1 3 5
  4. #4 Re: Multiple misfire?
    Oct 2011
    milford, michigan
    This could be a sign of your ICM going bad. when the motor heats up and tranfers heat to the ICM (which is connected to a steel mounting bracket and that bracket is connected to the cast iron head). When a bad ICM is heated up it will not function properly. It takes a while for this malfunction to occur because it takes a long time for the steel mounting bracket to become heat soaked.
  5. #5 Re: Multiple misfire?
    Someone just reminded me the other day.
    check the ICM connector to the coils. If you pulled it for any reason ..it might be loose.
  6. #6 Re: Multiple misfire?
    OOOO, I know who that was!
  7. #7 Re: Multiple misfire?
    Nov 2010
    I ran the code and it just says P0300 which is Random-Multiple Misfire. It does not say anything about which cylinders. So because of this it is probably not a plug or wire? And more likely the ICM? Not to sound like a complete noob but what and where is the ICM?
  8. #8 Re: Multiple misfire?
    Oct 2011
    milford, michigan
    The ignition coils are bolted to the ICM.
  9. #9 Re: Multiple misfire?
    Oct 2011
    milford, michigan
    You can remove your ICM and take it to an auto parts store such as auto zone and they will test it for free.
  10. #10 Re: Multiple misfire?
    Nov 2010
    ok thanks
  11. #11 Re: Multiple misfire?
    Just be sure to unplug the battery...because if your like I was the first time I removed it...I ground it out lol...and had to buy a new one regardless. $140 oops.
  12. #12 Re: Multiple misfire?
    Nov 2010
    Dang, thanks for the heads up
  1. Another idle surge/misfire problem with multiple codes
    By Justinzoso in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2010, 11:43 AM
  2. Multiple codes
    By silverstreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 12:35 AM
  3. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  4. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
