Thread: Guages
Results 1 to 16 of 16
  1. #1 Guages
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    not sure if i alrady asked this but i was curious as to what people think i should get for guages i have air/fuel and was thining short sweep oil and volt...anyone have other suggestions?
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: Guages
    Oklahoma
    Trans temp and oil pressure are always popular ones. Since you are n/a, I would think volts would be a better one than A/F. I have an A/F gauge and will be the first to tell you it is more for show than anything as the narrowband O2 sensor which it reads is not good and giving accurate a/f readings.
  3. #3 Re: Guages
    Barksdale AFB, LA
    Might also consider oil temperature. That's what I might be getting.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Guages
    Fayetteville, NY
    well i already got the a/f guage as a gift...lol so...
  5. #5 Re: Guages
    Oklahoma
    Well there ya go then. Oil temp is a great gauge to use. However, without a special adapter that goes between your oil filter and the housing (cant be used on the GP 3800 due to the proximity of the oil filter to the suspension such as the lower control arm) or taping into an oil feed of some kind in the block perhaps, they are hard to set up.
    I have not seen them used much in the GP community. However with me pulling out my engine and tranny, I plan on finding such a place that a valid temp reading could be taken from. We'll see how that all goes.
  6. #6 Re: Guages
    if it isnt a wideband a/f gauge its junk anyway. light show! wheeee!
  7. #7 Re: Guages
    Barksdale AFB, LA
    They're easy. A T-adapter at the oil pressure sensor...
  8. #8 Re: Guages
    Fayetteville, NY
    so you think oil pressure and volt would be good...?
  9. #9 Re: Guages
  10. #10 Re: Guages
    Fayetteville, NY
    how come trans temp and not volt? im just curious...
  11. #11 Re: Guages
    unless you got a system a volt gauge is pretty useless. its only good for diagnosing when your alternator is going out. save your money and buy that one later or something if you really want it.
  12. #12 Re: Guages
    Fayetteville, NY
    ok...im just trying to figure this out cause i have to buy 2 more gauges
  13. #13 Re: Guages
    Saraland Alabama
    I have had more alternators fail than bearings, so I think a volt gauge would be used more than an oil pressure gauge (I have had 1 engine that had an oil pressure issue) I am a bit weird I guess I want to know I have enough voltage for my electronic ignition at all times
  14. #14 Re: Guages
    if my car BEGINS to run low on oil i know it because of my oil pressure gauge. if it ever drops too low i will immediately shut the car off.
    spun bearings happen in like 15 seconds of running with not enough oil.
  15. #15 Re: Guages
    Saraland Alabama
    I know when my car is low on oil as I check it at least weekly (running low voltage can kill many parts including battery and pcm) what I am saying is you should have a volt gauge and oil pressure gauge ( only stock gauge that is worth having btw is a speedo the rest are so inaccurate as to be just decoration for the most part)
  16. #16 Re: Guages
    Fayetteville, NY
    ok i see...
  1. Guages
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-29-2008, 04:36 PM
  2. A pillar and guages
    Last Post: 02-25-2008, 05:45 PM
