Thread: Charging system failure
Results 1 to 6 of 6
  1. #1 Charging system failure
    Dec 2019
    US
    Chats
    Charging system failure followed by battery saver active when it dies it resets everything and starting disabled comes bk on dic sometimes bypass is needed others its not... I've changed starter, battery, alternator, terminal wires, electronic ignition switch all the fuses are new relays all look good... car starts engine runs just fine then suddenly after driving a while or car being on a while battery will die even while in drive it starts to idle really slow, lights dim, then engine shakes and kills... idk what to do next
    Sent from my SM-J260AZ using Tapatalk
  2. #2 Re: Charging system failure
    Chats
    98246
    Check the battery cables at both ends. Look for corrosion at the connections and where they ends are crimped onto the cable. Likely it's something super simple like corroded battery cables.
  3. Likes tiffanyfontenot99 liked this post
  4. #3 Re: Charging system failure
    Dec 2019
    US
    Chats
    Those have been changed also . I did just recently find out that my alternator is also grounded to my starter. So now im kinda at a hault bc dk exactly how the wiring is suppose to be. I should have a positive ground and my ignition wire connected to the starter solenoid. But now where does the positive lead from alternator go? Or can i remove that lead completely
  5. #4 Re: Charging system failure
    Apr 2014
    commerce twp,mi
    Chats
    i believe the positive from alt goes to fuse box on firewall. there should be a terminal off to the side.
    im a bit confused about positive ground- do you mean you have a good ground or do you have positive connected to ground?
    08 grand prix NA3800
  6. #5 Re: Charging system failure
    Apr 2015
    Columbus, OH
    Chats
    246
    Not positive, but double check the harness on the alternator. I left mine disconnected once and it did what you described. Do you ever see more than 12v? Might be that harness or the alternator you put on is bad. Was it a refurb?
    Top Swapped 01 Imp
  7. #6 Re: Charging system failure
    Dec 2019
    US
    Chats
    Yes it was refurbished.... i never really check voltage bc i was unsure how to use the volt meter but i will check it ouf today. And by positive lead i meant just the red positive cable
  1. Charging system failure
    By michaelbig in forum General Grand Prix Discussion
    Last Post: 09-03-2016, 04:17 AM
  2. Charging System Failure
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-14-2014, 11:35 AM
  3. charging system failure
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 07-19-2014, 01:30 PM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
