Thread: Removing MAF Sensor from Housing
Results 1 to 2 of 2
  1. #1 Removing MAF Sensor from Housing
    Jan 2017
    Alabama
    I'm replacing the Mass Air Flow sensor in my 06 GP. The local auto parts had the sensor only on the shelf, so I purchased that rather than ordering a sensor with housing. How does the sensor remove from the housing (Pull out, twist out, snap ring, etc)? I just got the sensor today, so I haven't been home to actually look at it. It may be simple, but I figured it wouldn't hurt to go ahead and ask in case there is a trick to it.
    Thanks for the help.
  2. #2 Re: Removing MAF Sensor from Housing
    Most the card style MAF sensors should come with like a little release card/tab dealio that you stick into it to release the MAF sensor. Then the new one will click into place.
  1. Removing maf sensor 04+
    By HVACgtp in forum General Grand Prix Discussion
    Last Post: 12-05-2012, 01:54 AM
  2. ABS/Traction Control Sensor Housing Cracked
    By timweidner in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2012, 05:53 AM
  3. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  4. removing dome light housing
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 01-16-2010, 06:45 PM
