Thread: Purge Valve or Fuel Pump issue?
Results 1 to 2 of 2
  1. #1 Purge Valve or Fuel Pump issue?
    May 2012
    Bloomington, IN
    Chats
    16
    '04 GP with 259k on it. I've been having an intermittent issue that I think I have narrowed down. There have been a handful of times, the car would crank and not start right away. I replaced the battery terminals (corrosion) and refreshed the body ground as well as adding another ground to see if that was a potential problem. Recently when it does start it will idle low and almost stall, but then rev-up and come back to life. Most recently I filled up the gas tank and then cranked a couple of times with no start. Finally, I was able to get it going. I've replaced the Vent Valve near the gas cap behind the left rear tire about 3 years ago. I also replaced the Purge Valve (upper intake) as I broke it during a LIM replacement about a year ago.
    So the typical culprits of a gas vapor issue, for the most part, have been eliminated and I'm thinking I just may have a fuel pump on the way out, but I wanted to see if it could be linked to any other issues or valves that could present such symptoms, thanks.
  2. #2 Re: Purge Valve or Fuel Pump issue?
    Dec 2012
    Where 4T65E's were born
    Chats
    22
    Seems every one 04+ that I work on does that. You can check the purge solenoid by ensuring air will not flow through it in the normal direction. I usually just check with my mouth, suck air from the engine side. Nothing should pass in that direction.
    Usually a throttle body cleaning solves that issue though, and check the Mass Air Flow sensor while you're there. The little sensors should look pretty clean.
    Sold.
  1. fuel pump issue?
    By SgtMarshal in forum General Tech Discussion
    Last Post: 02-16-2015, 12:24 AM
  2. Fuel Pump Issue?
    By Chad C in forum General Grand Prix Discussion
    Last Post: 02-20-2012, 08:24 PM
  3. fuel pump issue
    By MoarkatsINmuhtrailer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2012, 01:13 PM
  4. Possible fuel pump issue.
    By SleeperGS in forum General Tech Discussion
    Last Post: 11-29-2011, 01:58 PM
  5. Fuel Pump Issue
    By zildjian102 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:17 PM
