Thread: P0403 p0403 p0405 p1404....
Results 1 to 5 of 5
  1. #1 P0403 p0403 p0405 p1404....
    Jan 2019
    Indiana
    Chats
    I now know after replacing the EGR twice... thats not the fix. Any help please
  2. #2 Re: P0403 p0403 p0405 p1404....
    Chats
    98246
    It helps greatly if folks didn't have to look up the codes you are having issues with.
    P0403 - EGR malfunction
    P0405 - EGR below specified range
    P1404 - EGR Pintle stuck open
    Most of this is pointing directly to the EGR. Since you mention having replaced it without that fixing the issue, I would check the voltages going to it and inspect the wiring for any shorts. It is odd that you are seeing so many EGR codes.
  3. #3 Re: P0403 p0403 p0405 p1404....
    Jan 2019
    Indiana
    Chats
    I was aware of what the codes were just ignorant to where I begin tryin to fix them. Ty I'll check the wiring
  4. #4 Re: P0403 p0403 p0405 p1404....
    Jan 2019
    Indiana
    Chats
    0404 also
  5. #5 Re: P0403 p0403 p0405 p1404....
    Chats
    98246
    My point was.. you were maybe aware, but those people you are hoping to get help from may not be. Making them do extra work isn't usually ideal. I took the time to look them up to be able to give you some advice and hopefully it helps out.
  1. P1404 code
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2014, 10:39 AM
  2. Bad EGR Code P1404
    By indygrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2013, 10:50 AM
  3. P0403 EGR Demon - FIXED
    By SlowNA06 in forum General Tech Discussion
    Last Post: 11-12-2012, 11:19 AM
  4. P0403 -- Help
    By mckillin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 05:13 AM
  5. codes p0243 p0403 p0405 p0742 and p0010
    By IrishNation24 in forum General Tech Discussion
    Last Post: 06-11-2010, 05:13 PM
