Thread: water pump brand
Results 1 to 9 of 9
  1. #1 water pump brand
    Apr 2014
    commerce twp,mi
    Chats
    neewb here with a new-to-me '08. replacing heater hoses, serp belt tensioner ( and the elbows) idler pulley plus system flush tomorrow and thought while im over there and have all that off it might be wise to put in a new WP. im lookin for recommendations on brands and not sure if what to look at or what to stay away from would be easier.
    i did a search and see a lot of threads but didnt notice one talking about brands of pumps but maybe i missed it.
    thanks for any insight.
  2. #2 Re: water pump brand
    St. Louis
    Chats
    I've been running a Murray (O'reilly brand) pump on my 3.8's for years and haven't had an issue yet other than just wearing them out. They seem to last quite a long time.
    One thing I will mention is that make sure you have the correct torque specs for the WP bolts and also use a PTFE sealer on the bolts as some pass through water jackets. This will ensure you don't have coolant creeping around the bolts in the future. Also, IIRC the pump gasket on the 3.8 motor is a dry install so you shouldn't need any RTV on it. I used just a thin layer anyway to ensure any variations in the mating surfaces were sealed but that's it. No heavy bead needed. As long as both surfaces are clean and not gouged up (i.e.- the timing cover) then it should be a piece of cake.
  3. #3 Re: water pump brand
    Chats
    83662
    Whatever the top brand is at napa, I forget the name but it's like $35-45 and comes with gasket and really good warranty.
  4. #4 Re: water pump brand
    Apr 2014
    commerce twp,mi
    Chats
    napa sound like a plan. been gettin on a first name basis with the counter/parts man the last week as ive been going through basic tune up/maintenance stuff plus brakes,hoses,fluids, trans filter/lines, and all that good stuff thats needs maintaining.
    thanks,fordman,too. i dont know if i would have caught that about the thread sealant. i also put a thin layer of RTV on most gaskets.
  5. #5 Re: water pump brand
    Dec 2013
    Enfield
    Chats
    I think the AC has a better impeller design, may or may not make any difference.
    More Information for ACDELCO 252693
  6. #6 Re: water pump brand
    Apr 2014
    commerce twp,mi
    Chats
    Quote Originally Posted by rottonj View Post
    it would be intersting to see the impeller. i picked up a napa one-part#42097. napa box and branding and stamped "gates."
    water pump brand Attached Images
  7. #7 Re: water pump brand
    Apr 2014
    commerce twp,mi
    Chats
    heres the impeller side
  8. #8 Re: water pump brand
    Chats
    83662
    Either are good. You gotta figure that each company has put tons of hours into R&D as well as time on some sort of flow dyno to meet or exceed certain specs.
    My previous job has been using Napa/Gates pumps for well over 10+ years without any major issues. It's a mass produced part so a failure every once in a while is going to happen no matter who's part you purchase.
  9. #9 Re: water pump brand
    Apr 2014
    commerce twp,mi
    Chats
    agree with that. i used to set up,run, and repair screw machines. they'd kick out bad parts now and then and hard to tell when.
  1. Bad water pump?
    By markpa in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2017, 08:07 PM
  2. How do I know if my water pump is bad?
    By Matticus in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2013, 08:38 PM
  3. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  4. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  5. Water Pump
    By blaqdiamondz46 in forum General Tech Discussion
    Last Post: 11-11-2011, 05:25 PM
