Thread: Engine Stall with MAF plugged in, unplugged revs high
Results 1 to 4 of 4
  1. #1 Engine Stall with MAF plugged in, unplugged revs high
    May 2012
    Bloomington, IN
    I just changed out the power steering pump and did the water pump with everything off. I also did the LIM as I had a small leak out of the sides. I put everything back together and now it will crank and start for a second but then die right away. I had the ignition control module checked which was fine, I have 55 psi at the fuel rail. I then unplugged the MAF and it started fine but then revved super high seemingly out of control. I figured it might be a bad MAF so I swapped it out and the same thing occurred. It would crank start and then die. I unplugged the new MAF and then it revved super high.
    I'm at a loss. Is it my throttle body or TPS, perhaps a bad PCM. Please let me know I'm completely stuck.
  2. #2 Re: Engine Stall with MAF plugged in, unplugged revs high
    May 2012
    Bloomington, IN
    Also, I have no CEL codes whatsoever.
  3. #3 Re: Engine Stall with MAF plugged in, unplugged revs high
    check to see if the maf fuse blew, its marked ign. you can also make sure the maf's pig tail wires are in good shape.
    also make sure all your vac lines are back on and not broken. they get crappy and dont like to be messed with later in life.
  4. #4 Re: Engine Stall with MAF plugged in, unplugged revs high
    May 2012
    Bloomington, IN
    Facepalm... the brake booster line was not fully engaged... runs like a dream now
  1. Issue after intercooler install, car revs high then drops way low
    By Beatdowncity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2015, 06:05 PM
  2. Found something unplugged in engine bay? No idea what it goes to?
    By Runicdionysus in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2014, 07:16 PM
  3. 1999 Grand Prix GT Trans revs high
    By pilgrim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 12:42 AM
  4. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  5. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
