Thread: Built 4t65e - The results are in.
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 21 to 40 of 238
  1. #21 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    Got some of the stuff today.
    Shown:
    Master kit w/ pistons
    Bushing kit
    Washer kit
    Stater support bearing
    Lube dam
    Filter
    Magnets
    Bob made a good point on the bushings. For $27, I went for it. Just need to figure out how to get them all in...
    Hey Bill, don't leave me hanging!!
  2. #22 Re: Fall transmission build - Has begun!
    Ooops..
  3. #23 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    So this came today!
  4. #24 Re: Fall transmission build - Has begun!
    Apr 2015
    NJ
    any particular reason you went with 2.93 gears?
  5. #25 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    No ONE reason in particular. But here's how I ended up with the 2.93 setup.
    1.) It's the standard ratio for the supercharged cars. Whoever buys it won't NEED a tune to use it. (When I eventually sell my car, I'm pulling the built trans and selling it separately)
    2.) According to the TEP website, "The 2.93 ratio set is what we suggest and use for all builds making 400+whp and has proven itself to be the most durable."
    3.) I don't drive it a ton, but when I do, it's like 75% highway. My mileage already sucks, a lot. I higher ratio would only make that worse.
    4.) Availability. I bought them used. It's what the guy had. Honestly, that trumped everything else.
  6. #26 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    Got the new bushing pushed into the stater support. My hillbilly press worked pretty good. I didn't want to use a hammer and socket.
    Very little damage, if any, to the bushing.
    Also dissembled, inspected, and reassembled the input/3rd sprag assembly.
  7. #27 Re: Fall transmission build - Has begun!
    So um this rebuild is for me right? I don't care what these other assh0les say your a good dude. HAHA
    I'll send you a PM for shipping address once your done.
  8. #28 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    Quote Originally Posted by MyNameBlows View Post
    Money talks.
    By the time it's all said and done, it should be pretty close to the Triple Edge. 4T65E-HPS3
  9. #29 Re: Fall transmission build - Has begun!
    Buffalo
    Looking good man
  10. #30 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    Thanks Bob. I'm really taking my time with this one. Pouring over every detail, and researching as much as possible. All the old posts from Trannyman95 (Dave @ TEP) are a gold mine.
    Speaking of TEP, looks like I'll be needing an input clutch apply piston from him too. I won't be using this one.
  11. #31 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    Didn't get much time with it today. Small steps.
    Old bearing out.
    New bearing in.
    Manual shaft and seal in.
    And this came in the mail.
  12. #32 Re: Fall transmission build - Has begun!
    Buffalo
    I wish I could have done what you are doing. Seems like every time I broke a trans, I had to have it fixed yesterday (my car was a daily for awhile )
  13. #33 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    I hear you. I hate being in a rush. When it's done, I always feel like I could have done something better. Not this time...
    I can get a (mostly) working core from the pick-a-part soooo cheap. It would be silly to try to pull my current trans, rebuild it, and reinstall it in any reasonable amount of time. Plus, by doing it this way, I'll have a working transmission on the shelf as a backup in case anything happens to one of the 3 supercharged w-bodies in the family.
  14. #34 Re: Fall transmission build - Has begun!
    Mar 2014
    Tucson
    New bushing goodness.
  15. #35 Re: Fall transmission build - Has begun!
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    New bushing goodness for sure. Most people skip them because of the difficulty of replacing. On a couple of the ones that I've done I was able to skip them because they were cores that were both below 40k on them.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  16. #36 Re: Fall transmission build - Has begun!
    well happy to see my new trans has new bushings now too thanks!! lol
  17. #37 Re: Fall transmission build - Slow and steady progress
    Mar 2014
    Tucson
    Quote Originally Posted by GMR Badass View Post
    Now that I've done it, I definitely think it's worth the effort.
    Got the reluctor wheel mounted to the drive sprocket.
    My bonded separator plate came today. $15 shipped on Ebay from a dealership closeout.
    Fortunately, it was undamaged in spite of USPS's best efforts to destroy it.
  18. #38 Re: Fall transmission build - Slow and steady progress
    Mar 2014
    Tucson
    Almost done with the bushings,
    Only one left is the driven sprocket support.
  19. #39 Re: Fall transmission build - Slow and steady progress
    Mar 2014
    Tucson
    Made a trip to the trans shop today to get some more parts
    10pc. Input clutch set
    And a chain
    I probably know where all this stuff goes
  20. #40 Re: Fall transmission build - Slow and steady progress
    Mar 2014
    Tucson
    More work after a lunch break
    Got the final bushing in
    I cut a little slot in it to relieve some of the interference
    It doesn't get much closer than that
    There's two bushings leftover. One for the diffy cover of a non hd unit, and I think the other is for the torque converer
    Scuffed/buffed the sealing surface of the 2nd clutch drum
    Verified the function of the housing check ball
    Assembled the 2nd clutch assembly dry, then checked the clearance. I like it
    Now the clutches can soak
  1. A Stray cat ripped open my screen and welcomed himself into my home
    By acidcrashdburnd in forum Off Topic Discussion
    Last Post: 06-13-2012, 08:48 AM
  2. Taz's Offical Summer/Fall build list.
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 01:23 PM
  3. my build, need opinions
    By nascartech in forum General Tech Discussion
    Last Post: 10-03-2011, 10:53 PM
  4. ScreamsOfTheSouth Build / Need Opinions
    By z3r0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2011, 10:24 AM
  5. Lookin for opinions here.. Engine build
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2009, 08:11 AM
