Thread: 97 gtp shifting problem
Results 1 to 5 of 5
  1. #1 97 gtp shifting problem
    SE Level Member ScreaminZ's Avatar
    Feb 2014
    United States
    Chats
    The car will shift hard when it's not in performance shift mode. It will jolt the car and it will even jolt when the converter goes into lockup. But when I have performance shift on it shifts smooth and perfect. I'm thinking it's gonna be a sensor but I'm new to the 4T65 HD
    97 GTP stock
  2. #2 Re: 97 gtp shifting problem
    Feb 2014
    United States
    Chats
    Note: the car does have a check engine light on and when I got it scanned, code P1811 came up. The explanation was "the ECM has detected the shift execution time has exceeded the required shift time period" it goes on to say that some probable causes could be, A1- trailer towing may falsely set code (I don't tow) A2- low line pressure, plugged filter or pump, A3- computer relearn may be required
    A2 makes sense to me since performance shift probably just boosts your line pressure so it would make up for any lack of pressure while it's not in performance shift mode
  3. #3 Re: 97 gtp shifting problem
    Chats
    243824
    a shift kit is a good band aid fix for that code.
  4. #4 Re: 97 gtp shifting problem
    Feb 2014
    United States
    Chats
    What do you think the real fix would be though?
  5. #5 Re: 97 gtp shifting problem
    Chats
    243824
  1. problem shifting
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2013, 09:39 PM
  2. shifting problem
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 01:06 PM
  3. 95 GP Shifting problem
    By DaveB in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-22-2011, 03:53 PM
  4. Shifting Problem
    By taximech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2010, 07:06 AM
  5. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
