Thread: Single 1" chain vs double 1/2" chain
Results 1 to 17 of 17
  1. #1 Single 1" chain vs double 1/2" chain
    Jun 2013
    Jax Fl!
    Chats
    I haven't been able to find any info on this subject but since the 1" chain is so expensive to produce apparently and as far as I've read not in production currently why couldn't a double chain be used with two smaller chains? I'm not sure how many MEs there are on this board and I am still working on my undergraduate ME but I don't know any pro/cons to two smaller chains. Any insight? Seems like a cheaper alternative to the hard to find and expensive 1" chain for these transmissions.
    2006 Holden Monaro I Black with Red I H/C/I
    2001 GTP I
    Red with Black I Stock DD
    Kyne Tuned
  2. #2 Re: Single 1" chain vs double 1/2" chain
    GTP Level Member
    Pittsburgh
    Chats
    the factory setup is two chains currently. Its the strength that the GM Racing 1" provides
    2003 SSEi,
  3. #3 Re: Single 1" chain vs double 1/2" chain
    Chats
    49253
    if your breaking 7/8th chain then you need to pay to play....... then you need to look into the zzp 1 inch chain zzperformance.com or ask around neither the zzp one or a real GMR 1 inch chain will be had for under 1k. GMR 1 inch chains to pop up in the classifieds once in a while because people demod all the time and quite honestly this is a dying platform so just troll the classifieds.
  4. #4 Re: Single 1" chain vs double 1/2" chain
    Jun 2013
    Jax Fl!
    Chats
    Yeah I realize where to buy the chains, I'm wondering what the stresses are that a dual 1/2" chain set up isn't as strong as a single 1" or even a single 7/8" provides. What's the physics behind it. To me two 1/2" chains would seem to be stronger than a 7/8" but that's the upgrade. So would two 7/8" chains be stronger than a 1"? I assume there is only enough room for 1" so that wouldn't be feasible. Is it that the stock chains are made inferior too? Could the Gemini design be fixed and made stronger. Maybe I worded my question better this time.
  5. #5 Re: Single 1" chain vs double 1/2" chain
    Chats
    64942
    One set engages while the other disengages.
    So only one of the two is engaged at any given point in time.
    It's quieter, but not as strong.
    Another interesting point: http://en.wikipedia.org/wiki/Roller_...Chain_strength
    Seems it's all about the pitch. Width just happens to follow that.
    Strength also appears to go up much faster than chain width or even pitch does.
  6. #6 Re: Single 1" chain vs double 1/2" chain
    Chats
    49253
    LOL if one is made of double 1/2" play-dough and the other is made out of 7/8" steel don't you think the 7/8" would be stronger. Its not the size that matters grass hopper its what its made out of and how the metal is treated. Hence why the zzp alternative chain is 1 inch but isn't as strong as the GMR ones.......
  7. #7 Re: Single 1" chain vs double 1/2" chain
    Jun 2013
    Jax Fl!
    Chats
    This makes sense, two chains only one is used at a time.
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    This doesn't really help.
  8. #8 Re: Single 1" chain vs double 1/2" chain
    Nov 2011
    NY
    Chats
    1651
    What he is saying is the material in the dual 1/2" chain is inferior to the material in the GMR (GM Racing) 1" chain... I'd run what you got till something breaks, then fix it, lol!
    As for the dying platform? Really? Only because nobody wants to sink $ into it and know it is a cheap man's raze Kar! Hahaha...
    But there are still plenty of these engines around, parts are available if you look for them and $ for $ is a good setup for a 2ton vehicle. I for one would rather find, fix and mod a GP, than pay $20k+ for a used beat to crap newer car that is supposed to be fast. At least with the GP I know what I got, lol.
    I have (3) by the way, so maybe I'm a little biased!
  9. #9 Re: Single 1" chain vs double 1/2" chain
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Chats
    From what I've encountered in a 4t65e there's no way that only one chain can run at a time. Both chains drive the gears together. One chain doesn't disengage while the other engages.
    They are both engaged at all times.
    But the 7/8 and 1"chain are quite a bit stronger than the stock dual chains.
  10. #10 Re: Single 1" chain vs double 1/2" chain
    Jun 2013
    Jax Fl!
    Chats
    The GTP is my DD/ drive in the rain car. I don't consider them to be very fast but it sucks that the engine is so good but it's mated to the Achilles heal of the platform with this transmission. If I want a powerful car I'll get in my GTO, but mine isn't best to crap and probably the cleanest GTO that I've ever seen.
  11. #11 Re: Single 1" chain vs double 1/2" chain
    May 2008
    Schuyler, NE
    Chats
    265
    Quote Originally Posted by Twizted 1 View Post
    The gears are offset. So, only one chain is being pulled on at a time....well, not completely, but that's kind of how it works.
  12. #12 Re: Single 1" chain vs double 1/2" chain
    Jul 2013
    Summertown Tn
    Chats
    Ookie dokie..... Lol.
    The chains are the same length, the gears are offset the same amount.
    The only reason the gears are offset is because of the pins In the chains. It was designed to keep the pins on each chain from hitting one another, not for each chain to pull separately. The chains each pull the same at the same time.
    OP, unless your running over 300-320HP I would buy a set of Gemini dual chains from a 2004+ 4t65e and run the hell out of it.
  13. #13 Re: Single 1" chain vs double 1/2" chain
    May 2008
    Schuyler, NE
    Chats
    265
    No, actually the reason the chains are offset, is to reduce the noise it makes. They produce opposite frequencies that cancel each other out.
  14. #14 Re: Single 1" chain vs double 1/2" chain
    Jul 2013
    Summertown Tn
    Chats
    Yea that too.
    But it still doesn't have anything to do with the chains driving separately. Lol
  15. #15 Re: Single 1" chain vs double 1/2" chain
    Dec 2012
    Where 4T65E's were born
    Chats
    22
    I think that when they say driving separately, that since they're offset, the most force goes through the one with the tooth at the right angle. Since they're not at the same angle, one may take more torque than the other, back and forth. Am I on the right track? I always knew they were offset to reduce noise but didn't think about any other differences til now.
    Sold.
  16. #16 Re: Single 1" chain vs double 1/2" chain
    May 2008
    Schuyler, NE
    Chats
    265
    Yes, that's correct. That's not 100% the way it works, but it's close enough for this conversation.
  17. #17 Re: Single 1" chain vs double 1/2" chain
    Dec 2012
    Chats
    22
    I don't understand how that works or how it's possible to work like that, that's just what I picked up from reading this thread lol
    Sold.
  1. Omg 1" chain
    By MoarkatsINmuhtrailer in forum General Grand Prix Discussion
    Last Post: 07-22-2013, 08:17 PM
  2. Gemini dual chain or 7/8" single?
    By crbquist in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2013, 06:10 PM
