I'm looking for the part # to the bearing that sits right where the output shaft reaches the channel plate, Directly under the Driver side axle seal. I cant seem to find that bearings name or part number anywhere.
Washer, 4T65E 4th Clutch Hub to Channel Plate (3 Tab) 1997-Up
Part# 84421
Ref# 24207063
On this PDF it's Item # 275 "caged needle bearing - Chan plate to axle" but doesnt list a part # (TBA which I'm assuming means it doesnt have a part number?)
That Part # & ref is for the thrust washer, which I have.
http://www.daccoinc.com/pdfs/catalog...T60E_4T65E.pdf
Ah, in your original post you should have said it was a needle bearing. The part number that I gave was for the washer.
Also please read your other post about your car....
Did say it was a bearing. And input is greatly appreciated xD
