Thread: 4t80e swap into grandprix
Results 1 to 20 of 21
  1. #1 4t80e swap into grandprix
    Nov 2012
    pa
    i was wondering if a 4t80e can be swap into a gtp if not what would be the best stock trans to mate up with a built 3800 with out having to buy a zzp trans
  2. #2 Re: 4t80e swap into grandprix
    Charles City, IA
    No point to, they are not much stronger. Get a triple edge trans.
    SMGPFC Two Nipple General
  3. #3 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    triple edge trans ?
  4. #4 Re: 4t80e swap into grandprix
    Charles City, IA
    triple edge performance.
  5. #5 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    ow is the newer gxp vtrans alil better then my out dated 1 or just the same deal
  6. #6 Re: 4t80e swap into grandprix
    Charles City, IA
    Same thing.
  7. #7 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    damn so im spending 2k moreless
  8. #8 Re: 4t80e swap into grandprix
    Charles City, IA
    More like 4k.
  9. #9 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    wow thats my last investment im buying a 95 gp se next week to swap my built l67 into it so yeah could i use my trans in that frame or the 1 in it and if i do get to use my hd do i have to make my own cvs to fit into the 95 hub?
    Ohio
    A 4t80 is world's stronger than a 4t65e..
    The pain of it is fitting that big ****er in the engine bay
  11. #11 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    how hard of a swap and will it hold up to a cammed full bolt on tune p&p blower gen v 3.25 pulley etc ?
    Ohio
    That's ***** **** to that trans.
    As for how hard of a swap...
    Do you like drilling into the block?
    Are you skilled enough to wire the trans harness in?
    Can you fabricate new mounts for the placement of the transmission?
    New axles... Custom size I believe.
    Tuning the computer for the Trans.
    Drilling the flex plate for the 4t80 converter.
    That's most of it.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    http://www.gmforum.com/performance-b...thread-229424/
    Outdated and for a different car but good info
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  14. #14 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    yeah **** that lol i need a trustly trans with out spending 1k
  15. #15 Re: 4t80e swap into grandprix
    new britain, ct
    you wont find a trans thatll hold the power you want to make for less than 2k.
    i can almost guarantee that lol
    07 Black GXP.
    Ohio
    Idk why gm ****ed up like this.. They give the bullet proof trans to the ****ty fail wheel drive v8s...and the bullet proof engines get the glass transmission
  17. #17 Re: 4t80e swap into grandprix
    Quote Originally Posted by coreysGTP View Post
    GXP trans won't work without swapping outer shell
  18. #18 Re: 4t80e swap into grandprix
    Nov 2012
    pa
    how hard is swapping the outer shell out ? besides im swapping my built motor and whatever trans i get into a 95 the best gps IMO
  19. #19 Re: 4t80e swap into grandprix
    new britain, ct
    gxp trans is still a 4t65.
    07 Black GXP.
  20. #20 Re: 4t80e swap into grandprix
    Jul 2012
    Chicago
    You could probably find a junkyard trans for WAY less than $1k that will hold you over while you save up for decent built one.
    -Carl
  1. 4t80e forum
    By turbocharged406sbc in forum Forum Bugs/Suggestions
    Last Post: 08-13-2014, 09:05 AM
  2. 98 grandprix engine swap 3100 to 3800
    By TheBlackReaper in forum General Tech Discussion
    Last Post: 05-16-2011, 01:49 PM
  3. 1988 grandprix tranny to 1993 grandprix
    By avaitors in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 09-14-2009, 03:34 AM
  4. New to the grandprix!
    By SnMman in forum Introductions/Noob Questions
    Last Post: 06-23-2008, 01:30 AM
