Thread: Can't get key out after putting car in park.
Results 1 to 8 of 8
  1. #1 Can't get key out after putting car in park.
    Jun 2010
    Iowa
    Can't get key out after putting car in park. Sometimes I will hear a click and it will come out. I don't know if I need to adjust the cable or replace a part.
  2. #2 Re: Can't get key out after putting car in park.
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    I just posted this a couple days ago...
    there's a little button underneath the steering column you can push with a screw driver after you get the cap off. It'll let your key come out. Easiest way to fix it is to zip tie the button down. Mine's worked great for over a year now. If I recall correctly, three torx screws gets the lower half of the cover off.
    ...otherwise you replace the solenoid....
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  3. #3 Re: Can't get key out after putting car in park.
    Jun 2010
    Iowa
    Thanks. I'll give it a try and let you know if it works.
  4. #4 Re: Can't get key out after putting car in park.
    Donating Users ARFF22's Avatar
    NEW YORK
    Had the same problem for years with my car. Just used a small screw driver to push the button in on the steering column that I kept in that little pocket in front of the gear shifter in the center console. Became a real pain in the ass, especially when ever I had to valet the car. Eventually got it fixed, it ended up being the cable that runs from the shifter to the column that releases the key when it is in park. Had the dealership do it while it was in for some other work being done. I do not know what exactly the part was called but heard it is a pretty involved process. Also heard it is a pretty common problem with our cars, so I'm sure some one on here can be a little more helpful if that is the case. Good luck!
  5. #5 Re: Can't get key out after putting car in park.
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    i just took the solenoid out and you can turn the car off in any gear and take the key out...
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  6. #6 Re: Can't get key out after putting car in park.
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I can reach the button through the hole in the steering column plastic, no need to zip tie or carry a screw driver. It doesn't happen all the time, so I never bothered with a permanent fix.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  7. #7 Re: Can't get key out after putting car in park.
    Jun 2010
    Iowa
    Fixed! Used the zip-tie method. Thanks to all of you.
  8. #8 Re: Can't get key out after putting car in park.
    Jul 2010
    rainier oregon
    I'm having the same prob so i'll try the zip trick thanks
  1. Putting bigger motor in.
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-30-2009, 07:26 PM
  2. Putting Motor In
    By dcbur2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2009, 10:44 AM
  3. Anyone ever try putting a 5 speed or something in a 97+ GP?
    By salannelson in forum General Tech Discussion
    Last Post: 11-15-2009, 01:11 AM
  4. putting those vinyl inlays on how do i do it
    By olds95supreme in forum Visual/Body Modifications
    Last Post: 07-15-2009, 11:26 AM
  5. Putting the car in Reverse while driving.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-05-2008, 10:22 PM
