Thread: Clunk from diff going into reverse
Results 1 to 5 of 5
  1. #1 Clunk from diff going into reverse
    Ne
    New here, but hopefully I'll be around for a while.
    Lately when going into reverse there is a clunk that I assumed to be coming from CV shafts. Those were replaced with new units roughly 2 years ago with somewhere around 40k mi. on them now. I can jack up the car and turns wheels forward-reverse by hand and there is that bit of play that I would assume to be normal, but not sure if it should be more positive than that. Also noticed that drivers side shaft will lift a bit when going into reverse.
    This leads me to my next question which could be answered by looking at a breakdown, but are there bushings that the shafts are supported by, or is everything supported by the differential? I cannot remember off the top of my head what the splines looked like when the shafts were changed, but it may be worth pulling the drivers side just to check.
    There is no noise going from reverse or park to drive, only forward or park to reverse.
  2. #2 Re: Clunk from diff going into reverse
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Mileage? I sispect lower engine/trans mounts.
  3. #3 Re: Clunk from diff going into reverse
    Ne
    Which one commonly goes out? I've heard to check them, but they "appeared" good from when I had it in the air and had someone running the gears.
    Attempted checking them when I bought the car, but I ended up splitting my chin open on the fender when my prybar slipped.
  4. #4 Re: Clunk from diff going into reverse
    Las Cruces, NM
    Just replace both of them. Its not hard and if you're over 75K they need replaced anyway
  5. #5 Re: Clunk from diff going into reverse
    Ne
    Well, the transmission mount was tight. I replaced the hydraulic mount, which didn't turn out to be as easy as I had expected. Didn't fix it. I picked up a set of used CV shafts, so I'm going to try and swap in the drivers side shaft and see if it goes away. If not I guess I'll be replacing the transmission mount as well. Hopefully it's not something inside the trans. that's causing this.
    Thanks for the help
  1. weird clunk
    By MikeGTP88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 04:13 PM
  2. HD Diff???
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-31-2008, 08:26 AM
  3. Pop/Clunk Sound
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2008, 02:59 PM
  4. 2004 Grand Prix GT suspension clunk
    By McVaaahhh in forum General Tech Discussion
    Last Post: 04-19-2008, 01:04 PM
  5. Tranny whine after diff and diff case replace...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 09:27 PM
