Thread: 2004 Impala Transmission Clunk in reverse
Results 1 to 2 of 2
  1. #1 2004 Impala Transmission Clunk in reverse
    May 2020
    Pennsylvania
    Chats
    Good evening everyone. I am hoping someone can help. I recently changed my flex plate by dropping the transmission. I put it back together and it started nicely but now it has a loud clunk in the transmission. I feel it on the housing about 6 inches in on the housing. This is a nw noise. Fluid is full, I replaced the mounts while I had the cradle down, and I double checked the cradle bolts and mount bolts. Everything seems installed properly. I removed the half-shaft and reinstalled in because I thought it was not seated properly but it was. I am at a loss on this one. I am not sure why it's clunking. Both O2 sensors are throwing codes too but I think that's a sensor I forgot to plug back in. Any thoughts or ideas?
    I appreciate your insights.
  2. #2 Re: 2004 Impala Transmission Clunk in reverse
    St. Louis
    Chats
    Check the flexplate bolts as they may be loose.
  1. transmission clunk
    By Grimsin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2014, 06:22 PM
  2. Loud clunk noise shifting from neutral to reverse?
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 04-14-2013, 06:52 PM
  3. Clunk or grinding sound when shift into reverse
    By Coldwaves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2013, 12:50 PM
  4. clunk going into reverse????
    By vader99 in forum General Tech Discussion
    Last Post: 01-20-2010, 07:44 PM
  5. Clunk from diff going into reverse
    By TZFBird in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2009, 10:02 PM
