Thread: 02 GTP trans vs 04+GTP trans?
Results 1 to 3 of 3
  1. #1 02 GTP trans vs 04+GTP trans?
    Jan 2018
    US
    Chats
    Can anyone describe and give a visual what's different between these transmission. In eternally and externally?
    Sent from my SM-N975U using Tapatalk
  2. #2 Re: 02 GTP trans vs 04+GTP trans?
    Chats
    83662
    Going off memory the valve body is for sure different. The way the transmission is controlled through the wiring harness is different as well.
    2003 is when they started to change things up.
    Found the post through google because I don't have facebook.
    Can I modify a 1997-2002 4T65E... - GM 3800 Transmission Section - 4T65E | Facebook
  3. Thanks showtastiik thanked for this post
    Likes showtastiik liked this post
  4. #3 Re: 02 GTP trans vs 04+GTP trans?
    Jan 2018
    US
    Chats
    Thanks! I wonder If the spacer plate holes are the same? I know 03+ spacer plates have molded gaskets
  1. '04 Trans Swap - What parts should I replace on donor trans before installation?
    By zookman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2016, 06:50 PM
  2. 98 GP Trans, 03 Chevy 3.8L N/A & TRANS, Inner & Outer Rockers
    By robmurt90 in forum For Sale - Parts
    Last Post: 08-21-2015, 05:39 PM
  3. non-super 3.8 trans vs. supercharged trans?? Any difference
    By chicagochuck in forum General Tech Discussion
    Last Post: 06-19-2014, 11:54 AM
  4. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  5. trans surging and trans temp issues.
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2013, 08:29 AM
