Thread: Leaking input shaft seal DIY
Results 1 to 3 of 3
  1. #1 Leaking input shaft seal DIY
    May 2012
    Bloomington, IN
    Chats
    16
    I have an '04 GP 256k on the clock. Looks like I have a leaking input shaft seal and wanted to know the difficulty in replacing. I've done quite a bit and realize this would mean taking the tire, caliper, tie rod end, lower strut bolts, axle nut all off. I wasn't sure how difficult it is to physically remove the axle or put it back in. There are some good vids on youtube with other cars, but it would appear its somewhat straightforward.
    Let me know if there's anything to look out for, this would be the passenger side axle as well too.
    Other than a pickle fork or tie rod breaker tool, anything specialized I need. I have the seal remover.
    Thanks.
  2. #2 Re: Leaking input shaft seal DIY
    May 2012
    Bloomington, IN
    Chats
    16
    Output seal... I mean output seal
  3. #3 Re: Leaking input shaft seal DIY
    Chats
    98246
    Remove tire
    unbolt brake line from body 10mm
    Remove axle nut 35/36mm
    remove ball joint cotter pin
    Remove 18mm ball joint castle nut
    Pop ball joint
    Pull knuckle forward and slide axle out of hub
    hold knuckle out of way and use a tool to give the inside cv cup a quick tug.
    Axle is out and you are ready to do your seal
  1. input shaft seal leak.
    By GXDEMON in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-08-2018, 06:47 PM
  2. Replies: 9
    Last Post: 08-15-2016, 04:25 PM
  3. Kent Moore input shaft seal install tools
    By BrandonHall10 in forum For Sale - Parts
    Last Post: 07-23-2015, 08:10 AM
  4. 4T65E-HD Input shaft seal removal
    By BoilerTom in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-07-2012, 10:14 AM
  5. Axle Shaft Seal?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2009, 11:02 AM
