Thread: Problem with 07 GXP trans.
Results 1 to 3 of 3
  1. #1 Problem with 07 GXP trans.
    Feb 2019
    Michigan
    My 2007 GXP will not go forward in D. It will go forward in M. After achieving some speed, I can switch it to D and it will continue to go, until coming to a stop again. It downshifts when tapping the brake. Any suggestions whats going on ?? Thanks. Ckain
  2. #2 Re: Problem with 07 GXP trans.
    My guess says you lost the forward band.
    Putting the shift into 1 or in your case manual mode you are by passing the band and going directly into 1st gear. Once you reach a certain speed normally going into 3rd gear it'll continue to shift 3rd and 4th as normal until you drop down to slower speeds or stop.
  3. #3 Re: Problem with 07 GXP trans.
    Dec 2013
    Enfield
    I believe putting it in manual mode also raises the line pressure which could be helping also.
  1. trans problem
    By BLACKanREDgtp in forum General Tech Discussion
    Last Post: 04-07-2015, 12:25 PM
  2. trans problem?
    By jim97regalgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2012, 11:54 AM
  3. GTP Trans Problem
    By 04srmGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2011, 04:03 PM
  4. Trans problem. Please help!
    By stevenk8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2010, 02:18 AM
  5. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
