Thread: 2008 GXP Grand Prix Transmission Failure
Results 1 to 17 of 17
  1. #1 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    Yesterday, while driving about 40 mph, when I tried to accelerate, the trans acted like it was in neutral--no drive, no reverse. There was no noise--it acted like I shifted to neutral. Car has 166,000 miles, but I've only had it two years, so don't know the previous history, but suspect the trans was rebuilt at least once.
    Had the car towed to our local transmission shop. Tech says $2,300 for rebuild with a two year, 24,000 mile warranty. He has done others like this and suspects the converter failed. In his opinion, the small torque converter is the weak point with these GXP transmissions. They have an Impala there right now with the identical drive train and similar failure.
    I plan to go ahead with the rebuild, but would like to hear if any of you have info that would help prevent this from recurring.
  2. Advertisement
  3. #2 Re: 2008 GXP Grand Prix Transmission Failure
    Oct 2014
    portland oregon
    Chats
    507
    unfortunately the transmission is the weak point of the transmission. There are parts you can buy to toughen it up but, if you don't beat the crap out of it the basic rebuild should last you.
    better converter, shift kit, input shaft are a few things that come to mind. check out triple edge performance so see what they have. don't know how long you can go with out your car to figure out your best options
    Sent from my SM-N920V using Tapatalk
  4. #3 Re: 2008 GXP Grand Prix Transmission Failure
    Dec 2013
    Enfield
    Chats
    Quote Originally Posted by bocoogto View Post
    Get that quote in writing, that seems very low. Also ask about the components they will be using for the rebuild, as it was already stated there are some parts that would be a good upgrade to use. Any good reputable shop knows all about the shortcomings of these transmissions, make sure you ask about any options before they start. Good luck, post back your outcome.
  5. #4 Re: 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    As I stated, this shop has done quite a few of these transmissions on Impalas and Pontiac Grand Prix's. It's a local reputable shop, so I have no qualms about the quoted price or warranty. Their estimate on completion is two weeks out due to how busy they are.
    Technician says the weak point is the torque converter and a larger one is not possible because of the bell housing design. The converter has a lock-up clutch, which may be what failed.
    I'm looking for specific suggestions on what components are available that would improve reliability. I'm also hoping this rebuild gets rid of the nasty shudder that shakes the car every time I stop in "Drive."
    2008 GXP Grand Prix Transmission Failure Attached Images
  6. #5 Re: 2008 GXP Grand Prix Transmission Failure
    Dec 2013
    Enfield
    Chats
    That shudder may be a motor mount, and should be changed if accessible when getting the transmission rebuilt. Sonnax , Superior Transmission Parts, or TransGo all make upgraded components. The shop will already know about these but its up to you to ask for any options.
  7. #6 Re: 2008 GXP Grand Prix Transmission Failure
    Chats
    96430
    Another thing is ask the shop if they use the standard stack of clutches per the manual or if they check clearance etc. A shop that knows these transmissions very well will not put the standard number of clutches/plates in and consider it fine as they are known to have a bit of excess slop in the packs.
  8. #7 Re: 2008 GXP Grand Prix Transmission Failure
    Mar 2014
    Tucson
    Chats
    1786
    I would make sure whatever TC they use is top quality. Can't stress this enough. I saw a GM srta trans give up the ghost in under 50k. TCC shredded and sent grit through the whole thing.
    Edit: Click the link in my sig to see what goes into a "built" 4t65e.
  9. #8 Re: 2008 GXP Grand Prix Transmission Failure
    Chats
    36
    also add in an auxiliary trans cooler if you don't have one already.
    01 Z28 A4 HP-self-tuned, LTs, FTRA, 3600stall 12.5@110mph
  10. #9 Re: 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    Talked to technician today. He ordered the kit from TransGo. I called TransGo and they said they have only one kit for this transmission. Technician also said he ordered a premium converter. His experience with these transmissions is that failure to use premium rebuild components results in too many failures, which cost the shop money honoring the warranty.
  11. #10 Re: 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    Technician said he ordered the converter and all other parts from TransGo, including their shift kit. Will be interesting.
    Since I won't be drag racing, road racing, or pulling a trailer, why a transmission cooler? I've never seen the transmission temperature above 190 degrees.
  12. #11 Re: 2008 GXP Grand Prix Transmission Failure
    Chats
    36
    the trans fluid from factory goes through the radiator and during the hot summers, if you're running the stock t-stat which is a 195*F, the overall temps in both coolant and trans fluid will go well above 200*F. with stop and go traffic as well as spirited driving in the hotter weather the temps will go up further. the overall heavier weight of the GXP itself adds load to the trans and heat.
  13. #12 Re: 2008 GXP Grand Prix Transmission Failure
    Dec 2013
    Enfield
    Chats
    The LS4 cars suffer from engine compartment heat soak as everything is so tight. Different geographic location may see more favorable transmission temps if you live in areas that don't see high heat ranges,but it is good money spent as these cars should have had these installed factory installed and for sure heat has played a big part in the overwhelming transmission failures in these cars. It really should be first thing added , and installation is very straight forward if you decide to do it yourself. I really never thought mine ran hot either, usually right around 190 until I got stuck in a traffic jam and watched it climb to 240+ . Consider it an investment in your new transmission.
  14. #13 Re: 2008 GXP Grand Prix Transmission Failure
    Jul 2010
    Coquitlam,BC,Canada
    Chats
    Summer freeway driving (driving home from work) for less than 60 minutes.....
    The radiator does a great job cooling the coolant, but it sucks at cooling the trans fluid. Stupid design as far as I'm concerned.
    Chris B
    2002 GT
  15. #14 Re: 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    Transmission rebuild was finished this past Monday. Failure was caused by a sheared pump drive shaft through the center of the converter. Repair cost was $2,300 with a 2 year, 24,000 mile warranty. The transmission had been replaced in the past with a GM rebuild--the sticker was still on the torque converter.
    The shudder I previously posted was caused by a broken lower motor mount, which was replaced while the trans was out. This eliminated the downshift shudder AND an annoying clumking whenever a bump in the road was hit. I though the struts were bad, but since the motor mount replacement, the car rides like a new one. 166,000 miles on original struts that still work well is amazing!
  16. #15 Re: 2008 GXP Grand Prix Transmission Failure
    Dec 2013
    Enfield
    Chats
    Good deal, and a nice price. That's a sharp looking car, don't see a lot of red in my area. Good luck with it.
  17. #16 Re: 2008 GXP Grand Prix Transmission Failure
    GTP Level Member
    Oct 2014
    Chats
    Changing the fluid evert 25k. Helps as well.
  18. #17 Re: 2008 GXP Grand Prix Transmission Failure
    Sep 2017
    Winneconne, WI
    Chats
    I appreciate the comments about fluid temperature and changing fluid. But, note that my trans failed due to a sheared pump drive shaft--no relation to fluikd condition or temperature. My trans did have fresh synthetic ATF that was not discolored nor did it smell burned.
    Thanks for the suggestions.
  19. Advertisement
  1. ISO: 2005-2008 Grand Prix GXP transmission
    By Bloodpython171 in forum Wanted To Buy - Parts
    Last Post: 03-27-2016, 04:35 PM
  2. Heater blower motor and DIC failure - Intermittent 03 Grand Prix GT
    By tichign in forum General Grand Prix Discussion
    Last Post: 01-03-2016, 04:55 PM
  3. Common AC Leak Points or Failure Grand Prix
    By mainecrab in forum General Tech Discussion
    Last Post: 05-24-2015, 12:27 PM
  4. What's the failure rate on the GXP transmission?
    By Xanthous in forum 5.3L V8 (LS4)
    Last Post: 04-02-2015, 01:49 PM
  5. 2008 grand prix
    By khayes in forum Introductions/Noob Questions
    Last Post: 05-27-2011, 06:34 PM
