Thread: Anyone know the size fittings for trans cooler?
Results 1 to 3 of 3
  1. #1 Anyone know the size fittings for trans cooler?
    SE Level Member GXDEMON's Avatar
    Oct 2018
    The land of slow Grand Prixs, IL
    Chats
    Hey, Im gonna instal a Mishimoto HD trans cooler with a fan in my GXP and i need to figure out what the fitting sizes are for the return lines on both the radiator side and trans side. The cooler uses slip on barb fittings so i need to find those fittings if anyone knows what they are.
    Im extremely sarcastic, remember that when reading my responses.
  2. #2 Re: Anyone know the size fittings for trans cooler?
    Dec 2012
    Where 4T65E's were born
    Chats
    22
    So you would rather run 3/8 hose the entire length instead of tapping off the existing transmission cooler lines?
    Sent from my SM-G930T using Tapatalk
    Sold.
  3. #3 Re: Anyone know the size fittings for trans cooler?
    Oct 2014
    portland oregon
    Chats
    507
    I have a 97 so I don't know how it relates to your situation. I just cut off the rubber lines that come off the stock hard lines and connected there bypassing the radiator.
    My finger in on the return line.. or maybe it's the other way around either way the other line is on the bottom in the pitcure.
    Located on the driver side of the engine bay
    Sent from my SM-N920V using Tapatalk
  1. Trans cooler fittings
    By green97 in forum General Tech Discussion
    Last Post: 08-24-2016, 04:57 PM
  2. Trans Cooler Rubber Hose Size
    By Bronco Boy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2015, 11:33 AM
  3. 2004-2008 Pontiac Grand Prix Trans Cooler A/N Fittings for Radiator
    By CW2Lido in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2014, 01:23 PM
  4. What size AN fittings for fuel rails?
    By machinegunsquid in forum General Grand Prix Discussion
    Last Post: 01-29-2013, 08:55 AM
  5. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
