Thread: input shaft seal leak.
Results 1 to 4 of 4
  1. #1 input shaft seal leak.
    SE Level Member GXDEMON's Avatar
    Oct 2018
    The land of slow Grand Prixs, IL
    Anyone know what would cause an input shaft/torque converter seal to leak? i was thinking overheating. The chick i got the car form says that a shop/shops told her that the seal will just go bad 3 days after replacing it....
  2. #2 Re: input shaft seal leak.
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I've seen it be a damaged torque converter before, but it could really be a lot of things. Never had one leak on me after replacing, but the way I see it, if I've already gone far enough to replace it, I'm going to replace the torque converter itself and the seal, and the o-ring while I'm there imho. Brandon or Bill might have a few more insights.
  3. #3 Re: input shaft seal leak.
    Oct 2018
    Quote Originally Posted by wstefan20 View Post
    I havent replaced it yet but i dont understand how the shop knew that the seal would go out shortly after replacing it without taking it apart and as far as i know.She said that it wasnt replaced but that "every shop in illinois said it will go out 3 days after replacing"
  4. #4 Re: input shaft seal leak.
    That is stupid. Unless they think the seal wore a groove and will not seal for long after. I haven't come across any deep grooves on a TC like you do on the harmonic balancers. When you go in to do this, pressurize the converter as well (I cupped my hands on it and blew into it) I have seen a converter develop a leak/crack before that I couldn't see with my eye until fluid pushed out of it.
  1. Replies: 9
    Last Post: 08-15-2016, 04:25 PM
  2. Kent Moore input shaft seal install tools
    By BrandonHall10 in forum For Sale - Parts
    Last Post: 07-23-2015, 08:10 AM
  3. 4T65E-HD Input shaft seal removal
    By BoilerTom in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-07-2012, 10:14 AM
  4. Transaxel output shaft bearing and seal question
    By Tony48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2011, 01:13 PM
  5. Axle Shaft Seal?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2009, 11:02 AM
