Thread: CV boot separation during LCA change
Results 1 to 3 of 3
  1. #1 CV boot separation during LCA change
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    While changing the lower control arm on the passenger side, I managed to pull the axle out from the trans, separating the boot. Was able to stuff it back in and re-seat the boot, but could not manage to get the boot clamp re-installed. I need to take it to my mechanic for the alignment and have him reinstall the clamp, is it safe to drive it ten or so miles with no clamp on the boot?
  2. #2 Re: CV boot separation during LCA change
    I would use a couple of good zip ties at the least and get them as tight as possible. The only real issue is if it leaks the grease all over.
  3. #3 Re: CV boot separation during LCA change
    Oct 2016
    Davisburg, MI
    So in searching for a replacement clamp, I realized that I have used similar clamps in the past from Oetiker. They get their final tension from crimping a small area on the clamp. I was able to un-deform the crimp area, install it back on the boot, them re-crimp it to tighten. Problem solved!
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. New thread separation?
    By Pure2sin in forum Forum Bugs/Suggestions
    Last Post: 03-15-2012, 03:48 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
