Thread: Pan leaking
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Pan leaking
    Donating Users GaGTPGuy's Avatar
    Feb 2019
    Ga
    Chats
    Thanks. I should not expect oil to swap through gasket??
  2. #22 Re: Pan leaking
    Chats
    243824
    they tend to leak as well. but ive found the bolts to be the source a few times now. when i did my pan gasket i used a thin smear of rtv on the block and pan and sealed the bolts, no leaks 3 years later.
  3. #23 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Hopefully, it’s not too late.
  4. #24 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    I can’t seem loctite at local car shops.
  5. #25 Re: Pan leaking
    Chats
    243824
    theres other brands, permatex works fine
  6. #26 Re: Pan leaking
    Feb 2019
    Ga
    Chats
  7. #27 Re: Pan leaking
    Chats
    243824
    thats fine to use.
  8. #28 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    I hope this does the trick. Pan looked good for the most part although, I have not crawled under yet. Tomorrow will be my fun day.
  9. #29 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Applied Permatex pipe thread to each tranny bolt one at a time. They were all dry except for about two maybe three bolts. Took awhile. Thanks for help.
  10. #30 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Now onto oil pan. Looks like a pain. Had it done about 6 years ago. It's been leaking for awhile.
  11. #31 Re: Pan leaking
    Chats
    243824
    good lord, i thought we were talking about the oil pan...never noticed it was the trans section lol same bs applies.
  12. #32 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Lol...I was wondering.
  13. #33 Re: Pan leaking
    Chats
    243824
    the trannys pans the pan gets dimpled around the bolt holes and sometimes and needs to be hammered flat again. stock fat gasket works best, its re usable. the thin gasket that comes with a new filter is trash.
  14. #34 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    I did buy a new AC Delco tranny pan. I installed a Raybestos filter and gasket. Like I said pan was mostly dry. I am glad I applied sealant.
  15. #35 Re: Pan leaking
    Chats
    243824
    just repeat the same deal for the oil pan. you'd be like the 4th or 5 th guy ive told to try it and it seems they all stopped leaking.
  16. #36 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Can you send me to link for its removal. Seen a bunch of videos but they seem pretty scary.
  17. #37 Re: Pan leaking
    Chats
    243824
    the oil pan, id clean it up with brake cleaner, then try sealing all the bolts with the thread sealant first. then keep an eye on it for leaks, if it still leaks theres links on yt for the pan drop, you need a engine hoist to lift the engine up some and remove the ac compressor.
  18. #38 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Engine hoist? I maybe be chewing off more than I can handle. Will try sealant first. Lol
  19. #39 Re: Pan leaking
    Chats
    243824
    some times you think the pan is leaking and its a valve cover too. best to de grease the whole thing, do the pan bolts drive and keep checking for a leak. you can wipe under the lip of the valve covers to see if they are wet with fresh oil too.
  20. #40 Re: Pan leaking
    Feb 2019
    Ga
    Chats
    Valve covers are fine. It’s mosly pan bolts. Ugh
  1. Car leaking, not sure from where.
    By 04trbogp in forum General Tech Discussion
    Last Post: 05-25-2015, 10:20 PM
  2. Oil Leaking
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2014, 08:53 PM
  3. what is this? its leaking
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2013, 12:03 AM
  4. Leaking on the top
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 07:23 AM
  5. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
