Thread: Transmission Cooler Line fitting?
Results 1 to 4 of 4
  1. #1 Transmission Cooler Line fitting?
    Readsboro VT
    I might have some fluid leaking out of the transmission cooler line fitting at the transmission on my 05 GTP Comp G. Unfortunately, I can't find a fitting that matches what I've got.
    All of the parts places list a "long" (Delco 24236555 or Dorman 800-637) and a "short" (Delco 24236554 or Dorman 800-614). The problem is, my fitting doesn't look like either of them.
    Here's the "long":
    Here's the "short":
    Here's mine:
    Anybody know what part this is?
  2. #2 Re: Transmission Cooler Line fitting?
    If the thread pitch is the same and they take the same size cooler line they will work just fine.
    Likely only the dealership can find you the exact match.
  3. #3 Re: Transmission Cooler Line fitting?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Your fitting may be fine. You probably just need new o-rings on the outside and inside. Pretty common.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Transmission Cooler Line fitting?
    SE Level Member sn95gt50's Avatar
    Jul 2008
    2008 Grand Prix Base
    124,000 miles
    just looking for confirmation before hitting the purchase button from RockAuto, I know my lines are leaking, and the fittings are all wet as well, my just be coming from the lines, but plan to replace the fittings as well. The first two pics, I believe the first one is the long and the second one the short, The long one is the one that outlets downward and the short is the one that outlets horizontal, correct? The ones at the radiator look fine, plan to leave those alone.
    Follow up question, do not plan to drain tranny, how much tranny fluid is going to come out when I do this?
    Thanks,
    John
  1. Transmission cooler line
    By bakery07 in forum General Grand Prix Discussion
    Last Post: 08-19-2016, 09:46 AM
  2. Transmission cooler line flow
    By robinsone in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2015, 10:11 PM
  3. transmission cooler line to radiator size
    By KC04GTP in forum General Tech Discussion
    Last Post: 05-05-2015, 04:56 AM
  4. 2002 vs 1998 transmission line fitting
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2014, 11:26 AM
  5. Transmission cooler line
    By jhnnyboz in forum General Grand Prix Discussion
    Last Post: 08-24-2012, 08:03 AM
