Thread: Tranny Man
Results 1 to 6 of 6
  1. #1 Tranny Man
    Banned
    New Port Richey Florida
    Do you know were to get the specs of the trans's that backed the turbo 3.1's i've done some reasearch and those were hd's from gm cause of the turbo. but what parts went into them is my ? and could a regular trans like i have be built to that ones specs
  2. #2 Re: Tranny Man
    GT Level Member shaferz's Avatar
    Forrest IL
    Quote Originally Posted by 19SE92 View Post
    Contact Jeff Midaugh. I think he may still post over at the w-body.com forums.
    99 GTP = 12.936 @ 112.12 2.16 60'
    06 TBSS = STOCK
    07 GXP = STOCK - ordering SSC's
  3. #3 Re: Tranny Man
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Transmission/Transaxle is unique, and in a few key areas that owners would be hard pressed to duplicate with an aftermarket upgrade. Larger 3/8” tranny cooling lines, and an auxiliary stacked plate tranny cooler in the fender well area with dedicated air cooling duct. Hardened Gears and Gear Carrier Set. Additional nested accumulator springs, other little changes to the tranny, some not listed. The first 4T60 called the 440T4 was the first 4 speed front wheel drive automatic transaxle produced by an American automobile manufacturer. The 4T60 was a greatly redesigned 440T4, now vastly improved!
    Tranny Specs:
    Manufacture: Turbohydromatic; division of GM
    Plant location: Warren, MI
    Case material: Cast aluminum
    Weight: 192.57 lbs wet
    Style: Transverse mount for FWD application
    Type: 4T60=
    4: 4-speed, T: Transverse Mount, 60: Production Series (engine torque range)
    Maximum gross vehicle weight: 6,400 lbs
    Maximum gearbox torque: 368 lb-ft
    Fluid fill capacity from fully dry: Case/Lines/Coolers: 11 quarts, greater (unique) fill quantity over stock 4T60s
    Fluid fill capacity after an overhaul: 8.5L/18 pints/9 quarts
    Unique higher count clutch packs
    Unique valve body accumulator spring setup
    Unique channel plate arrangement
    Unique valve body and plates
    Gear count: 4 forward with lock-up torque converter, 1 reverse
    Forward gear ratios: 1st 2.921, 2nd 1.568, 3rd 1.00, 4th .0705
    Reverse gear ratio: 2.38:1
    Chain ratio: 35:35
    Maximum shift speed 1-2: 6,000 rpms
    Maximum shift speed 2-3: 5,500 rpms
    Maximum shift speed 3-4: 5,200 rpms but only the early 89s allowed WOT 3-4 shifts
    Torque converter type: Fluid drive, with friction pack lock-up clutches; available in 3rd and 4th gear based on load though past 83mph is fully locked at anything other than engine deceleration, or a brake application
    Torque converter capacity factor “K”: 177
    Torque converter size: 245mm
    Torque converter stall speed: 1898 rpms
    Differential gear ratio: 3.33:1
    Unique Differential construction: hardened gears and gear carrier and steel washers
    Control Type-Shift: TV/Throttle Valve cable for up shift and downshift points, and a centrifugal governor regulating line pressure for shifts as well.
    Control Type-Pressure: Vacuum Modulator regulated, referenced through a vacuum line just off the back of the upper intake inlet, regulated down by an in-line restrictor to allow the check valve/bleed valve at the modulator to bleed off a boost signal coming from the upper intake.
    Unique Cooling System: dual system; larger heat exchanger in the radiator end tank, and a unique auxiliary air to liquid stacked plate cooler located in the passenger front fender cavity. Also unique larger 3/8” cooling lines.
    Axle shaft manufacturer; Saginaw division
    Axle shaft type: Solid
    Axle shaft diameter left: 23.81mm
    Axle shaft diameter right: 27.06mm
    Universal joint type inner: Tripot joint, 27 sz, 66mm, ball and needle bearing
    Universal joint type outer: Rzeppa joint, fixed ball bearing
  4. #4 Re: Tranny Man
    Bastard Reptile's Avatar
    Kansas City, MO
    I thought you were some kind of expert on these things.
  5. #5 Re: Tranny Man
    SW Chicago Suburbs
    Quote Originally Posted by Reptile View Post
    come on, reptile... get it right... he's the expert with the 3.4 motor and it's trans... get it right!
  6. #6 Re: Tranny Man
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Toasty covered it and that is all identical information to what I have on these transmissions. As far as obtaining parts from a transmission parts supplier forget it, they dont list anything special and to the untrained eye no core supplier cares what it came from and all of the parts would have been sold as and with any other 440T4 parts. I have never built one of the turbo models so I cant say truth to any of the info. I have built tons of these a long time ago, its been at least 6 years since I have even been inside one as they just arent common ground since they are in the 20 year old range. I did build a lot of Cadillac 440T4s that supposedly had better or hardened geartrains but I never saw anything that wasnt run of the mill. For the swap car transmissions that I have built in the past I have never found hardparts to be of concern on these once built properly with the right parts and valve body upgrades which these transmission badly need.
  1. Motor and tranny mounts....
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2010, 09:00 AM
  2. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  3. tranny
    By bad1999gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 02:04 PM
