Thread: Spyder halo problems
Results 1 to 2 of 2
  1. #1 Spyder halo problems
    Mar 2015
    Michigan
    I have the cheap spyder halos from ebay...lol and for some reason my passamger high beam went out. I have 5 extra bulbs none seem to work, the wiring is fine. Is their a fuse or a ground or somethig i can check? Im stuck ive tried everything. I dont know what it could be.
  2. #2 Re: Spyder halo problems
    Aug 2013
    arlington, tx
    Do you have a volt meter? If you do, stick the probes in the connector and see what you get. Should be around 12V. Also check the connector and see if it's not backwards. The connectors can easily be mistaken if you just connect them by how it LOOKS like it will go (ask me how I know haha) Make sure the ground from the plug matches with ground on the connector.
  1. spyder halo question
    By InsaneGTP in forum Introductions/Noob Questions
    Last Post: 05-03-2014, 05:28 PM
  2. HELP!!!! spyder led halo install
    By cooper25 in forum 5.3L V8 (LS4)
    Last Post: 09-28-2013, 03:04 PM
  3. Spyder Halo Ring Size?
    By Points70 in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:06 AM
  4. spyder halo
    By Matt Palm in forum Visual/Body Modifications
    Last Post: 05-23-2012, 08:05 PM
