Thread: Capacity Specifications
Results 1 to 1 of 1
  1. #1 Capacity Specifications
    Omaha, NE
    Chats
    28500
    All following information listed is for a 04 N/A, It should remain the same for all 2004+ Naturally Aspriated or Supercharged applications. If any errors or variances are found please contact me via PM to have the information corrected.
    Automatic Transmission/Transaxle
    System Specifications
    AUTOMATIC TRANSAXLE
    Pan Removal 7.0 liters (7.4 quarts)
    Complete Overhaul 9.5 liters (10.0 quarts)
    Dry 12.7 liters (13.4 quarts)
    IMPORTANT: When draining/replacing the converter, more fluid will be needed.
    NOTE: ALL capacity specifications are approximate. When replacing or adding fluids, fill to the recommended level and recheck fluid level.
    Fluid- A/T
    Transmission Fluid
    Pan Removal 7.0L (7.4 Qt)
    Overhaul 9.5L (10.0 Qt)
    Dry 12.7L (13.4 Qt)
    Cooling System
    Engine Cooling System 10.6 liters (11.2 quarts)
    Coolant
    Engine Lubrication
    Engine Crankcase 4.3 liters (4.5 quarts)
    Engine Oil
    Engine Oil 4.3L (4.5 Qt)
    Fuel Tank
    Fuel Tank 64.0 liters (17.0 gallons)
    Hydraulic System, Brakes
    Information not supplied by the manufacturer.
    Brake Fluid
    Maintenance
    FLUID CAPACITY/LEVELS
    Note that ALL capacity specifications are approximate. When replacing or adding fluids, fill to the recommended level and recheck fluid level.
    Refrigerant
    Air Conditioning Refrigerant 2.3 lb. (1.05 kg.)
    Refrigerant Oil
    REFRIGERANT OIL CAPACITIES
    A/C COMPRESSOR REPLACEMENT 75 ml (2.5 oz)
    NOTE: The 7CVC service compressor is shipped with 5.0 oz of PAG oil. If more than the specified amount of PAG oil was drained from a component, add the amount drained.
    IMPORTANT: Compressor failure can occur if the oil removed during refrigerant recovery is not replaced.
    CONDENSER REPLACEMENT 60 ml (2.0 oz)
    EVAPORATOR REPLACEMENT 90 ml (3.0 oz)
    RECEIVER DEHYDRATOR REPLACEMENT 30 ml (1.0 oz)
    NOTE: Add PAG oil equal to the amount of oil drained from the old receiver dehydrator, plus the specified amount.
    ANY LINE SET (HOSE/TUBE OR TUBE ASSEMBLY) 30 ml (1.0 oz)
    TOTAL SYSTEM PAG OIL CAPACITY 240.0 ml (8.0 oz)
    Steering
    Power Steering Fluid 1.1 pints (1.0 liters)
  1. Towing Capacity
    By 07GXPLS4 in forum General Tech Discussion
    Last Post: 10-10-2011, 12:32 AM
  2. coolant capacity of 94 3.1 GP?
    By restlessrobb in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-04-2011, 01:32 PM
  3. oil capacity
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-06-2011, 09:51 PM
  4. Oil Capacity?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 02:33 PM
