Thread: What fuel pump you using?
Results 1 to 2 of 2
  1. #1 What fuel pump you using?
    Jun 2013
    Hollywood ,FL
    So I have a zzp 350lph fuel pump with re wire . Problem is when the cars just warming up will run 10.5 afr but as I race more or drive the car long distance the car leans out at wot sometimes 12,13 even 16+ afr my car is a 05 with re turnless fuel system im thinking this pump is overheating and getting too hot causing it to starve the engine of fuel im running 60* injectors and the ipw is at 90% somethings up
    Sent from my SGH-T999N using Tapatalk
  2. #2 Re: What fuel pump you using?
    GT Level Member ricio1991's Avatar
    Feb 2014
    Tempe
    I have a stock one i believe and its misfiring at wot only on highway speeds after like 90. I get a ticking sound at idle is that normal on a 04 gtp?
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  3. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  4. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
