Thread: P2135 code 2004 .....SOLVED
Results 1 to 7 of 7
  1. #1 P2135 code 2004 .....SOLVED
    Nov 2012
    Madison
    Chats
    Got the dreaded throttle position sensor code.
    The kinda needle in the haystack problem.
    All good if I don't go past half throttle. This is all happened when I had to hit it to merge into the correct lane.
    Instant pow when gassed and engine reduce power plus stabilitrak DIC.
    Checked when I got to work for wiring signs but didn't really see any(all done rather quickly)
    OK, read code, P2135 and nothing else, reset and on my merry way.
    Tomorrow I will clean throttle body and MAF and search for wire problems.
    Wish me luck.
    I am a fan of free fixes and not rabbit holes. Idon't want to buy a pedal and throttle body just to have the same thing happen when I play racekar.
    Let me know if you have encountered this POS GM experience.
    And hi yall, havent been around for awhile
  2. #2 Re: P2135 code 2004
    Nov 2012
    Madison
    Chats
    The cleanings didn't do it and I checked obvious wiring issues, none apparent.
    Although I did find my TB gasket was seeping antifreeze so replaced that.
    So screw it in the name of throwing parts.
    I ordered a new Throttle body and pedal from Rockauto. At least the car is usable up to 70.
    Keeping fingers crossed
  3. #3 Re: P2135 code 2004 .....SOLVED
    Nov 2012
    Madison
    Chats
    The POS rips in its own little way again.
    I replaced both parts, TB and accelerator pedal. Whichever one did it, no cares. I didn't want to dick around.
    Now I am going to dissect the throttle body.
  4. #4 Re: P2135 code 2004 .....SOLVED
    May 2012
    lebanon ohio
    Chats
    Glad you figured it out. I hope I don’t have to deal with this one day but sure I will.
  5. #5 Re: P2135 code 2004 .....SOLVED
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chats
    1417
    Quote Originally Posted by spazzz View Post
    When you get the black piece off the throttle, it looks sealed on the inside. There's like a lip or edge around the sealed up part. I chipped that away with a tiny screwdriver then you can look in there. Think I just glued it back shut, lol.
  6. #6 Re: P2135 code 2004 .....SOLVED
    Nov 2012
    Madison
    Chats
    Quote Originally Posted by SaukRapids View Post
    Did you replace your throttle body?
  7. #7 Re: P2135 code 2004 .....SOLVED
    May 2016
    MN
    Chats
    1417
    Actually, no. I bought another throttle cus the car was hesitating a little under moderate load. WOT was okay. Couldn't figure it out.
    Ended up putting the gasket back in even tho my coolant ports are blocked. "I'll see a leak if my dimes come out right away!" I thought I was so cool ..until that gasket made the car run again.
    I'd taken the OEM one apart thinking it was bad. Cleaned it with a pink eraser/qtips/alcohol in there, and sealed it up.
    That spare one's still on my shelf.
  1. 2004 GPGT P0341 error code
    By stbne in forum General Tech Discussion
    Last Post: 09-24-2017, 08:21 AM
  2. 2004 GTP with P0420 diag code
    By p coico in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2017, 12:11 AM
  3. 2004 GTP Code P0420
    By Gohan77 in forum General Tech Discussion
    Last Post: 08-30-2013, 05:01 PM
  4. Help please reduced engine power p2135 and p0122
    By jteske88 in forum General Tech Discussion
    Last Post: 06-30-2012, 04:41 PM
  5. 2004 with c0550 code
    By stevets61 in forum Forum Bugs/Suggestions
    Last Post: 10-26-2010, 07:18 PM
